QA1 uca's #2408619
11/25/17 12:40 PM
11/25/17 12:40 PM
TX
O
OSDart Offline OP
OSDart  Offline OP
O
TX
Anyone using the QA1 tubular UCA's on a 65' Belvedere? We're you able to achieve a 4° or 5° positive caster? Any problems with construction or quality?
Re: QA1 uca's [Re: OSDart] #2408722
11/25/17 05:00 PM
11/25/17 05:00 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I was able to get 4.6 degrees of positive caster in my 70 Charger using poly strut rod bushings, STOCK upper control arms with the Moog K7103 offset bushings.
Another way to go, much cheaper and stock appearing:
Lower ball joint camber spacers/washers! AndyF makes them, Mancini sells them. They allow for more negative camber, which, along with the offset bushings, allow the car to get more caster without the camber going into the positive range.
Re: QA1 uca's [Re: OSDart] #2408724
11/25/17 05:06 PM
11/25/17 05:06 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
