Re: 1200-1500hp - World iron hemi block? [Re: ] #2408199
11/24/17 12:23 PM
11/24/17 12:23 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I have one with pred heads that made 1200 on a single 4. I've since added a tunnel ram, and the car picked up mph, so I know it's making some undetermined amount more than that now. The car is 3400 pounds and runs high 5.20's to low 30's based on 60' which is rarely the same. sometimes it's 1.169, and other times it's 1.22 or slower on bad hits.
I've seen no signs of stress problems at this power, but blower torque may be a different story.
I would stay way clear of their aluminum block with a blower. Running over the crank doesn't sound like any fun at all lol.
Re: 1200-1500hp - World iron hemi block? [Re: ] #2408206
11/24/17 12:38 PM
11/24/17 12:38 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
Originally Posted By Superfreak
14-71 roots blower, GRP aluminum rods, Stage V custom heads 7000rpm max. Think it will hold together? I would probably need max hp at 1300. Car is built for 8.5 so......... and no desire to go faster.
WHO YOU TRYIN TO KID!! us or yourself? NO DESIRE TO GO FASTER haha
Re: 1200-1500hp - World iron hemi block? [Re: ] #2408214
11/24/17 01:10 PM
11/24/17 01:10 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
My World block has lasted several rebuilds of 1100 +. Al has a build that made really good power, I think over 1200. That's why I'm looking for another option. Mopar left me hanging. There aren't any options right now and hasn't been for quite a while unless you want to be their R&D division and your expense.
Re: 1200-1500hp - World iron hemi block? [Re: ] #2408237
11/24/17 02:10 PM
11/24/17 02:10 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Iron block + blower = safe. Same power from NA or nitrous would be worse stress.
What brand 14-71? What does the discharge window and manifold look like?
Boffin Emeritus
Re: 1200-1500hp - World iron hemi block? [Re: ] #2408342
11/24/17 06:00 PM
11/24/17 06:00 PM
Superfreak OP
Superfreak OP
Littlefield standard,prepped for gas. full open on the bottom IIRC. Manifold will be a Stage V piece. I have 2 - Quickfuel 1050 blower domi's, CP blower pistons, crank will be a Bryant billet center counter weighted piece.
Re: 1200-1500hp - World iron hemi block? [Re: ] #2408441
11/24/17 11:07 PM
11/24/17 11:07 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I know full rotor exposure doesn't seem critical for race, but (as in all helixed rotors) all the air is in the triangle formed by the rotor's relative positions just behind the drive nose. Air behind that point is just pulled back into the case and re-heated.
It looks to me that masking the case would be easy (Eaton just closes it up, no special shape) but it may mean moving the case to the rear of the manifold - which will move your pulley out of line. Some pictures may exist of a masked case on a manifold to hint at a good distribution spot (although some OEM Eaton manifolds are just open boxes).
Anyone read anything on this?
Boffin Emeritus
