5.9l MAGNUM HARMONIC BALANCER REMOVAL? #2408406
11/24/17 09:16 PM
11/24/17 09:16 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Am I going to have a special tool to remove the balancer? I have a tool that I have used on LA motors. But I am not seeing any holes to put my bolts in on this magnum balancer. Thanks Jim
Re: 5.9l MAGNUM HARMONIC BALANCER REMOVAL? [Re: rt66jim] #2408460
11/24/17 11:43 PM
11/24/17 11:43 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I helped a relative remove one a 99 Durango with a 5.9 years ago. We ended up using a large gear puller with a large diameter impact socket and washers stacked in the hole to keep the bolt from touching the crank threads. We got it off, but it wasn't easy.
You'll need the correct install tool to pull it back on. Don't try pulling them on with the bolt. Tempting, but you can wreck the threads.
Re: 5.9l MAGNUM HARMONIC BALANCER REMOVAL? [Re: rt66jim] #2408526
11/25/17 02:31 AM
11/25/17 02:31 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The correct tool makes it so much easier than using a generic gear puller as it will fit better.
Re: 5.9l MAGNUM HARMONIC BALANCER REMOVAL? [Re: rt66jim] #2408529
11/25/17 02:40 AM
11/25/17 02:40 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Autozone rents them for free..I rented a special sized one for our srt4
Re: 5.9l MAGNUM HARMONIC BALANCER REMOVAL? [Re: rt66jim] #2408604
11/25/17 11:23 AM
11/25/17 11:23 AM
Guitar Jones Offline
There is a small specialty 3 jaw puller for that style that works on a lot of them. If you do work like this it's probably worth it to buy one.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
