Indybrock rockers #2407847
11/23/17 02:05 PM
11/23/17 02:05 PM
Finally a HUSKER again
Moparnut426 Offline OP
I’ve got standard Harlan Sharp rockers now, but have some wear issues on the roller tip cutting into the rocker tip bodies. I know I have some pushrods clearance issues I have to clean up causing the issue with the rockers, but I want to switch to T&D. Do they use the same rocker shaft size, and Can I order individual intake and exhaust rockers from them since the indybrock head uses stock big block rockers on small block shafts?
Re: Indybrock rockers [Re: Moparnut426] #2408240
11/24/17 02:13 PM
11/24/17 02:13 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
If it's like the BB T&D rockers, they use a smaller OD shaft and collars on the shafts to match the OEM shaft diameter.
