Re: MSD mag pick up plug orientation
[Re: mopar dave]
#2409171
11/26/17 04:45 PM
11/26/17 04:45 PM
Posts: 1,807 Mopar Country, Mi
ccdave
The Ultimate
The Ultimate
Mopar Country, Mi
Could be the ice ignition box since this is the second msd dist with the same issue. Maybe just not compatible with this box. Crank trigger is best option thou . just search this issue. You will find a few with same issue and if you check msd trouble shooting section, there is a bunch. Have you bought an msd dist. In the last 4 or 5 years? I’ve purchased 2 or 3 in the past 3 years. No problems at all.
[Re: mopar dave]
#2409344
11/26/17 10:51 PM
11/26/17 10:51 PM
Posts: 43,096 Bend,OR USA
Cab_Burge
Is the ICE box suppose to retard after 5000 RPM? The old Hayes ignition(before it became stinger ignitions) ICU S4 boxes would do that
