Re: Stock 1970 340 T/A Block Compression Test
[Re: f2502011]
#2408689
11/25/17 03:34 PM
11/25/17 03:34 PM
Posts: 364 US
f2502011
US
Here's what I got. Much more consistent, but not so great. Warmed engine up to full operating temperature then began removing things and by the time I got everything off it was not too hot to touch. I used two batteries in a series and a charger. Cranked each cylinder 7 times (wanted to be sure) did dry test and wet test on each cylinder as I went along. I can see tons of carbon on top of the pistons. As far as I know the engine is likely just a refresh and never completely rebuilt. I believe it got new bearings, seals, rings etc. Anyway here it is first number dry second number wet. I started at the back right when the engine was the hottest and it was 95/107. Went back after finishing and it was 90/95 dry/wet so I through the first one out.
Right 78/84 80/85 83/95 90/95
Front---------------------------->Rear
Left 83/83 80/93 82/98 85/94
1970 EK2 T/A 727
[Re: f2502011]
#2408696
11/25/17 03:41 PM
11/25/17 03:41 PM
Posts: 96,649 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
looks good. Now make sure that your gauge is accurate, mine went bad the other year and was showing too light a pressure. Also make sure the timing chain isn't stretched. Also do the leak down test to check the rings and valves, etc.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#2408848
11/25/17 10:48 PM
11/25/17 10:48 PM
Posts: 364 US
f2502011
US
looks good. Now make sure that your gauge is accurate, mine went bad the other year and was showing too light a pressure. Also make sure the timing chain isn't stretched. Also do the leak down test to check the rings and valves, etc. I have a brand new gauge and will double check the pressure. Not sure how to check whether the timing chain is stretched or not?? Also purchased a leak down tester but am unsure how to perform the test as I have never done it.
1970 EK2 T/A 727
[Re: f2502011]
#2408852
11/25/17 10:53 PM
11/25/17 10:53 PM
amxautox
take the dist cap off
turn the crankshaft in one direction to top dead center mark
then turn the crankshaft in the other direction watching the rotor in the dist. when the rotor STARTS to turn, stop rotating the crankshaft
tell us how many degrees the crankshaft turns before the rotor starts to turn turns
Tom
author unknown
[Re: f2502011]
#2408853
11/25/17 10:53 PM
11/25/17 10:53 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
Um, just to clarify, cause it's pretty frikken important, I am sure you meant two batteries in parallel....not SERIES! GASP!
[Re: fastmark]
#2408855
11/25/17 10:55 PM
11/25/17 10:55 PM
Posts: 364 US
f2502011
US
Now that you have spent all this time on a cheap compression test, all it will tell you is you have a problem. Buy a leak down gauge and it will tell you what the problem is. My thinking was that the point of doing a compression test was to see if you have an issue and needed to do further testing and diagnostics to narrow down the issue.
1970 EK2 T/A 727
[Re: amxautox]
#2408861
11/25/17 10:58 PM
11/25/17 10:58 PM
amxautox
leak down testing/tester;
put each piston at their tdc on the firing stroke and screw the fitting in the sprakplug hole with the piston at tdc
supply 5 psi or so, air pressure and listen at the carb, exhaust, radiator, oil fill or dipstick holes. listening for any air coming out and bubbles in the radiator. Also if the kit has a gauge then watch for pressure drop in a given time span, should be noted in the directions with the kit.
Tom
author unknown
[Re: Pacnorthcuda]
#2408863
11/25/17 11:00 PM
11/25/17 11:00 PM
amxautox
Um, just to clarify, cause it's pretty frikken important, I am sure you meant two batteries in parallel....not SERIES! GASP! parallel is more amps = good series is more volts = bad. will burn out the starter.
Tom
author unknown
[Re: amxautox]
#2408866
11/25/17 11:07 PM
11/25/17 11:07 PM
Posts: 364 US
f2502011
US
supply 5 psi or so, air pressure and listen at the carb, exhaust, radiator, oil fill or dipstick holes. listening for any air coming out and bubbles in the radiator. Also if the kit has a gauge then watch for pressure drop in a given time span, should be noted in the directions with the kit. I'm sure it will be in the instructions but how do I know when each cylinder is at TDC?
1970 EK2 T/A 727
[Re: f2502011]
#2408869
11/25/17 11:10 PM
11/25/17 11:10 PM
amxautox
Start at #1, and use the firing order. Then stick a plastic rod, straw, or something that won't damage anything and won't break off in the cylinder, or use the pressure gauge, and turn the crank over by hand, it'll work out that way.
Tom
author unknown
[Re: amxautox]
#2408882
11/25/17 11:20 PM
11/25/17 11:20 PM
Posts: 364 US
f2502011
US
Start at #1, and use the firing order. Disclaimer: Please understand I have no experience of the process for a leak down test. To start the test I need to get #1 to TDC and do the leak down test. Next lets say I do #8. Question is do I just rotate the crank around to TDC again to get TDC on the next cylinder?
1970 EK2 T/A 727
[Re: f2502011]
#2408888
11/25/17 11:28 PM
11/25/17 11:28 PM
Posts: 43,123 Bend,OR USA
Cab_Burge
Bring the motor up to TDC on # 1 cylinder on the firing stroke and test it, rotate the crankshaft 90 degrees clockwise to test #8,and another 90 degrees to test #4 and test, then rotate another ninety degrees to test # 3 and go through the firing order in sequence to test the rest, one at a time (Imagine straight up as 0 degrees and 1/4 turn is 90 degrees Most car motors in the car are hard to get 90 degrees rotation with one movement, if you stop more than 5 degrees before or after TDC the air pressure will probably blow the piston down to bottom dead center, make sure and remove the ratchet or breaker bar from the socket or crankshaft bolt before each test If you don't you may regret what it breaks or damages, like your arm or radiator shroud The leak down meter will come with instruction, some are better than others, I own two, one old single gauge from Moroso that quit reading accurately years ago(it would stick ) and a newer one from Aircraft Spruce for testing my old airplane motor, it is a dual gauge tester and easier to use
[Re: f2502011]
#2408889
11/25/17 11:29 PM
11/25/17 11:29 PM
amxautox
Start at #1, and use the firing order. Disclaimer: Please understand I have no experience of the process for a leak down test. To start the test I need to get #1 to TDC and do the leak down test. Next lets say I do #8. Question is do I just rotate the crank around to TDC again to get TDC on the next cylinder? Yes, and you won't have to rotate the crankshaft very many degrees before the next piston gets to it's tdc.
Tom
author unknown
[Re: f2502011]
#2408985
11/26/17 02:51 AM
11/26/17 02:51 AM
Posts: 364 US
f2502011
US
Brand new gauges different results. Dry Test.
Right 120 135 125 130
Front-----------------------Rear
Left 128 129 136 130
1970 EK2 T/A 727
