EAGLE HEADS ON A 6.1 #2405201
11/17/17 10:17 PM
11/17/17 10:17 PM
Australia
aus370 Offline OP
aus370  Offline OP
Australia
I haven't seen any results of Eagle heads on a stock stroke 6.1.
I was hopeing some of the G3Hemi Masters here might have some insight .
I have a stock 6.1 in a Valiant , It has the Mahle drop-in forged pistons in it , unfortunately these drop the comp to around 10.0 ,combine that with a cam that I will eventually install , I think I'll be looseing alot of torque.
I have been Paying attention to some of the builds on here , and thats where the eagles come in , they should bring the comp up to 11.0 .
So a little home porting and maybe some 1.6 exhuast valves What sort of HP increase ????. worth it or just stay with my 6.1 heads.
Re: EAGLE HEADS ON A 6.1 [Re: aus370] #2406249
11/20/17 08:48 AM
11/20/17 08:48 AM
Australia
L4staero Offline
L4staero  Offline
Australia
Id like to know this too.
What would be the best choice for a 6.1 bottom end out of 6.1, 5.7 eagle or 6.4 heads? Anyone with some experience in this?
TIA
Re: EAGLE HEADS ON A 6.1 [Re: aus370] #2406654
11/21/17 03:36 AM
11/21/17 03:36 AM
houston texas
gremlinsteve Offline
houston texas
Well
I think your comparable on flow enough that it won't achieve
Much gain there if any
Compression bump should pick you up about 3-4 percent
I think your better off purchasing the right camshaft for the
6.1 combo using the 6.1 head
I have a camshaft I designed years ago that's been know to
Run rather well. And to be honest it's not that much as far as duration
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: EAGLE HEADS ON A 6.1 [Re: L4staero] #2406655
11/21/17 03:37 AM
11/21/17 03:37 AM
houston texas
houston texas
TIA
Can you rephrase your question so I can try to assist you better
Re: EAGLE HEADS ON A 6.1 [Re: gremlinsteve] #2406694
11/21/17 09:50 AM
11/21/17 09:50 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
TIA
I think he's talking Bottom end, Torque , Rpm below say 3500
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: EAGLE HEADS ON A 6.1 [Re: gremlinsteve] #2406695
11/21/17 09:52 AM
11/21/17 09:52 AM
Australia
aus370 Offline OP
aus370  Offline OP
Australia
So maybe around 15 HP for the compresssion increase ,
I see your point considering i don't have the eagles .
Your cams are you able to do something with a little more lift to take advantage of the valve reliefs.
Well
Re: EAGLE HEADS ON A 6.1 [Re: aus370] #2406708
11/21/17 10:41 AM
11/21/17 10:41 AM
houston texas
houston texas
Of course
If my memory serves me correctly your going to start seeing valvetrain
Issues in the .650 range
What lifts are you asking for
Re: EAGLE HEADS ON A 6.1 [Re: aus370] #2407229
11/22/17 06:32 AM
11/22/17 06:32 AM
Australia
aus370 Offline OP
aus370  Offline OP
Australia
From memory , i didn't measure , the valve reliefs looked around .080" deep . Most of the cams i see that are intended for stock 6.1's have around .560 valve lift , I was thinking something around .600" .
Re: EAGLE HEADS ON A 6.1 [Re: aus370] #2407231
11/22/17 07:38 AM
11/22/17 07:38 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Re: EAGLE HEADS ON A 6.1 [Re: aus370] #2407303
11/22/17 12:10 PM
11/22/17 12:10 PM
Mid West US
GoForBroke Offline
GoForBroke  Offline
Mid West US
I've got one even better. lol Called the MACH 3. 219/229 112 LSA 108 ICL fastest ramp rates the stock lifter will reliably handle. Not stepping on toes I hope just throwing it out there :-)
Re: EAGLE HEADS ON A 6.1 [Re: aus370] #2407336
11/22/17 01:19 PM
11/22/17 01:19 PM
houston texas
houston texas
I can grind u something in the .620 range with ease
Re: EAGLE HEADS ON A 6.1 [Re: aus370] #2407750
11/23/17 09:21 AM
11/23/17 09:21 AM
Australia
aus370 Offline OP
aus370  Offline OP
Australia
Now I'm spoilt for choice. What is the stock rocker ratio 1.6 , 1.65 , or somewhere inbetween.
