Page 2 of 2 < 1 2
#24094 - 05/09/06 05:41 AM Re: ok trans(727) problems again HELP [Re: fast383duster]
VernMotor Offline
Loc: Mt.Vernon ,Ohio
My r/t dakota will run. 8.99 so I will let her run it this weekend. 3500 stall converter. in coronet.
Racing is not a Hobby,But a way of Life 2000-2001 Pacemakers Major JR Dragster Champion 2005 PRO Class Champion 2006 PRO Class Champoin 2011 Mo-Power Pro champion (Jenni Vernon)
#24095 - 05/09/06 05:49 AM Re: ok trans(727) problems again HELP [Re: VernMotor]
fast383duster Offline
mopar addict
Loc: Johnstown, Ohio
We probably have a converter, and a trans if you want it for the weekend. If so call me
Edited by fast383duster (05/09/06 03:09 PM)
Ryan Goodin S/Pro B386 High Speed Graphix T-shirts, Signs and More! www.highspeedgraphix.com
#24096 - 05/10/06 08:18 PM Re: ok trans(727) problems again HELP [Re: fast383duster]
mopar addict
Well how are things going?
#24097 - 05/11/06 07:13 AM Re: ok trans(727) problems ( update better pics) [Re: VernMotor]
YbNoRmAL Offline
mopar addict
Loc: Indiana
Have you figured it out yet? Your mods look good but everything points to a lube problem. You said you blew the cooler out and it was good. What I realized sometime back is that air pressure is not the same as lube pressure. I've been able to blow air thru coolers before that wouldn't hardly move any fluid at all. With the tranny back in the car ,leave the back cooler line off and run the line into a bucket and start the car in neutral , you can actually watch your flow and time it. The older Chrysler service manuals says you should be able to pump at least a quart in 20 seconds. I'm just saying don't trust the air pressure method when checking or flushing a cooler.
#24098 - 05/11/06 08:20 AM Re: ok trans(727) problems ( update better pics) [Re: YbNoRmAL]
there's some good tech info here. I made it so this thread cannot disappear , then when it is done it will be moved to the tech archives.
#24099 - 05/11/06 09:10 AM Re: ok trans(727) problems ( update better pics)
VernMotor Offline
Ok I thought this got forgot about! my cooler is a take apart moroso in line with a filter and a magnet in it with blow off spring. so if the filter gets plug it still flows. . so I took it apart and clean it. lots of metal in it. put new filter in it.
I am at work I tell you more when I get home.
#24100 - 05/11/06 09:35 AM Re: ok trans(727) problems again HELP [Re: VernMotor]
MRMOPAR Offline
Loc: Tucson, Arizona
Looking at your good picture of the governor support... its pretty evident that something came thru the main lube feed to the output shaft based on the metal displacement from that hole towards the small feed that lubs the rear drum. That would seem to indicate something comming from the cooler area.
Edited by MRMOPAR (05/11/06 09:37 AM)
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
#24101 - 05/11/06 11:16 AM Re: ok trans(727) problems again HELP [Re: MRMOPAR]
dartman366 Offline
Loc: Mt. Vernon, Ohio
my thought's exactly, what ever it was I seriously doubt it was from the trans it self, converter get's my vote.
#24102 - 05/11/06 11:47 AM Re: ok trans(727) problems again HELP [Re: dartman366]
VernMotor Offline
Ok lunch time. First thing is A REAL BIG THANK YOU to Ryan Goodin (fast383 duster) for leting us use his spare trans and converter..Just so happen that it is the same converter I got. Now you look down in his and look down in mine .There no Question mine is hurt. so that is most of what happen here . but I think got other deal going on also. the oil hole mod to the sprage. We talked about this in other thread. carl book says 1/8 hole 3/4" in . well 3/4 in is right behine the outer race. I thould this was a miss print. I look at 440 jim site he has that about 3/8 in and is behine inter race. having the hole behine the outer race would not allow alot of flow. but behine the inter race that moves would let it have flow. so with having a 1/8 hole and behine the inter race. I might have too much going to the sprage. so I am going to put a set screw in there and go back to a 1/16 hole. I beleve that why I see the gaulding on the outside of the suport and not on the inside . fluid goes to the inside first. and with the converter going bad made it a conbined problem..Ryan trans is in seems ok. I going to post some more pics when I get time might be sunday. I got JR motor to build tonight and test&tune friday night and race on sat.Thanks to everone..we are learning. Might be the hard way. But We will win..... It might as well give up lol.. GOOD THING I AM I AUTO TECH..or might would of give up...
#24103 - 05/14/06 12:48 PM Re: ok trans(727) problems again HELP [Re: VernMotor]
VernMotor Offline
Ok got mine oil sprag hole plug with a set screw with a .60 hole in it. So that should not be anything to worry about no more see pic. and here is a pic of burn up bushings and a pic of nice clutchs . I found it hard to beleve that the bushing could look so bad and the clutchs look so good. And I mean every bushing in this trans look like this.
#24104 - 05/14/06 03:59 PM Re: ok trans(727) problems again HELP [Re: VernMotor]
screamindriver Offline
Loc: Harrisburg, Pa.
Jamie, I caught that measurement problem from the Carl book also when looking to add the sprag extra oiling. ..The measurement put it behind the outer race...Do you think that's the reason for the increased opening size??? Any spinning parts tend to sling oil away from the center...So what good would the oil hole do under the outer race pressurized or not ???? 440jims' site modification specs would seem to be the better way to go....
#24105 - 05/14/06 04:06 PM Re: ok trans(727) problems again HELP [Re: screamindriver]
VernMotor Offline
I agree thats why I did mine like jim's .I just got carry away with the 1/8 hole. should of read Jim's deal better.
#24106 - 05/14/06 08:09 PM Re: ok trans(727) problems again HELP [Re: VernMotor]
440Jim Offline
Loc: Southern Maryland
I have been running that sprag oiling mod for years. But I didn't come up with it, I just spread the knowlage/technique. I got it from John Kunkel.
Page 2 of 2 < 1 2
25,346 Registered Members
190,219 Topics
CARBON FIBER HOOD
by A/MP
Today at 12:22 AM
TUNING W2 HEADS
by A/MP
Today at 12:15 AM
727 clutch pressure plate gap newb question
by radar
Today at 12:01 AM
Dakota clip- who has done and retained the EFI?
by CrAzYMoPaRGuY
Yesterday at 11:26 PM
