It's Back! Over Charging Problem 68 Dodge Truck
#2407334
11/22/17 01:17 PM
11/22/17 01:17 PM
Posts: 2,554 Maryland
wally426ci
Maryland
Ok, I've been reading heavily everywhere to diagnose this.
Truck cranks forever & sputters when letting off the key. For the last 6 months it was starting often when letting off the key. I've read about voltage drop through firewall plug and bad ignition switches. I've improved the problem by either replacing or fiddling with ECU harness (converted to Mopar electronic ignition). That fix doesn't last long and it happens again.
I have a Volt meter in place of AMP gauge inside the truck and it is now reading at 10- while idling and getting close to 12 with rev. Previously, it was 11.5 @ idle and almost 14 with rev.
I know there are a lot of variables, but is there a diagram somewhere that shows me acceptable voltage readings to the corresponding point under the hood? I know there is expected drop for each component but trying to figure out what readings I "should" be getting.....
Thank you in advance!
Re: Finding the Voltage drop 68 Dodge Truck issue
[Re: wally426ci]
#2407346
11/22/17 01:43 PM
11/22/17 01:43 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
In order to know your voltage drop you have to know what is coming out of hte alternator.
10V at idle with 12V revved up is BAD.
11.5v at idle with 14 revved is also bad.
Since we have no idea where you voltmeter is actually tied into the system it's hard to say what it's reading. If you simply bolted the two ammeter connections together and used that point as the freed for the voltmeter then you should be reading alternator out put and if it's that low you have serious issues.
We may as well start at the beginning ...
What is the reading at the battery positive - (use engine block for ground)
engine off - engine at idle - engine at 2500 rpm -
What is the reading at the alternator stud - (use engine block for ground)
What is the reading at the coil positive - (use engine block for ground)
Once we have these we can go from there
[Re: 469runner]
#2407349
11/22/17 01:44 PM
11/22/17 01:44 PM
Supercuda
About to go away
About to go away
up yours
Check your Ballast resister. Ignore this. The ballast resistor will NOT have any affect on system voltage, which is very low. Nor is it used in START. It is bypassed with the key in START and the fact that it will sometimes start when the key is released shows it is good.
[Re: wally426ci]
#2407516
11/22/17 07:04 PM
11/22/17 07:04 PM
RapidRobert
Truck cranks forever & sputters when letting off the key. I've improved the problem by either replacing or fiddling with ECU harness (converted to Mopar electronic ignition). 4 pin orange box I am assuming. I would jump 12V from the battery positive post to the blue yellow ECU terminal and to the coil positive primary terminal & seperately (on the ground side) from the ECU base to ground then crank it & see if it starts several times in a row & only let it run for several seconds if/when it does start to confirm or elim the coil/ECU are good tho they can be OK when cold then act up when hot but you did say this was an initial in the morning starting problem. then as said check voltage drops at the coil/ECU when cranking OR just start cleaning ALL terminals/connections especially the bulkhead & ign sw.
[Re: wally426ci]
#2407700
11/23/17 02:36 AM
11/23/17 02:36 AM
RapidRobert
Thank you for the kind words & I could use a vacation but the thought of the airport delays would probably make me want to stay put. for the charging rate I would confirm that the battery is full charged by slo charging it with a charger to full charged then put it on a fast idle & see what you get at the alt & at the batt terminals. I'm wondering if this is a charging rate or a voltage drop (connections/terminals) or a part (coil/ECU/switch) issue. The battery could be sulphated (least likely) but a possible potential. We're getting there.
[Re: RapidRobert]
#2407705
11/23/17 02:52 AM
11/23/17 02:52 AM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
Truck cranks forever & sputters when letting off the key. I've improved the problem by either replacing or fiddling with ECU harness (converted to Mopar electronic ignition). 4 pin orange box I am assuming. I would jump 12V from the battery positive post to the blue yellow ECU terminal and to the coil positive primary terminal & seperately (on the ground side) from the ECU base to ground then crank it & see if it starts several times in a row & only let it run for several seconds if/when it does start to confirm or elim the coil/ECU are good tho they can be OK when cold then act up when hot but you did say this was an initial in the morning starting problem. then as said check voltage drops at the coil/ECU when cranking OR just start cleaning ALL terminals/connections especially the bulkhead & ign sw. Wally, As FastBob states above, check your bulkhead connections. Your comment "sputters when letting of the key" is a classic indicator that the STARTING circuit to the ignition has failed. Not uncommon.
[Re: wally426ci]
#2408735
11/25/17 05:42 PM
11/25/17 05:42 PM
Supercuda
About to go away
About to go away
up yours
As Andrew said, 15.5 is probably too high, your idle is too low. Your coil voltages look ok and where you have checked I do not see a voltage drop issue. I would say voltage drop to the voltage regulator on the sense side needs looked at, usually it's a blue wire but it is the switched 12V feed to the VR. Measure that to engine block and it should be the same as the battery + terminal or alternator output stud voltages, if not you have an issue if so it's probably the regulator. In 68 you should still have the single field terminal alternator with the mechanical regulator system, unless it has been changed. If you are still running the mechanical voltage regulator instead of the later electronic version of it (not to be confused with the 70 and up regulator) you can adjust turn on and turn off voltages. To tell if it's the mechanical regulator look at the bottom, if it has a couple wire wound resistors it's the mechanical one. The FSM has adjusting procedures in it. No truck FSM's, but the 68/69 pass car ones have the relevant info in them http://www.mymopar.com/index.php?pid=109I would think about converting to the newer charging system http://www.mymopar.com/index.php?pid=78
[Re: wally426ci]
#2408747
11/25/17 06:53 PM
11/25/17 06:53 PM
wally426ci
Maryland
I have not probed the regulator points. I did swap the regulator for no change. I then decided to swap another alternator in. That changed the volt ratings inside the truck and it now pulses by a half an amp or so.. See my youtube upload https://youtu.be/6DkWHOLzsxk
[Re: wally426ci]
#2408748
11/25/17 06:57 PM
11/25/17 06:57 PM
Supercuda
About to go away
About to go away
up yours
that is what a mechanical regulator looks like when it's doing it's thing.
[Re: wally426ci]
#2408800
11/25/17 09:24 PM
11/25/17 09:24 PM
Supercuda
About to go away
About to go away
up yours
If you have the newer setup and it's doing that you have a problem.
[Re: wally426ci]
#2408817
11/25/17 10:01 PM
11/25/17 10:01 PM
RapidRobert
that charging rate is too high. I'm thinking this 2nd electromechanical reg is the problem, a considerably way less 2nd choice would be the alt. I would certainly want to get an electronic reg which most parts house types are now (have no wire wound resistors on the bottom side of it) & a Wells 706 (iirc) was the last electronic one I got but it dont look OE (if that is critical). For sure the starting issue ain't a lack of voltage but it is critical to get this dealt with first as that high of voltage will fry (or significantly shorten the life) of bulbs and any electrical component that is "on" while it is charging that high. As said jump from the batt positive post to the "ign" terminal on the reg but your (posted) voltage drops are about as perfect as I have ever seen & a voltage drop might not be the issue (easy/free to check). I'm assuming the reg is grounded well since it has been changed & confirm the block is grounded well to the firewall/batt neg post. Backing up a bit I'm assuming you have a 2 field terminal alt with one terminal grounded.
[Re: wally426ci]
#2409318
11/26/17 10:16 PM
11/26/17 10:16 PM
RapidRobert
You know I was out jogging today & it crossed my mind that the unsteady ammeter needle would be from an electromechanical reg that ain't quite right or alt brushes/commutator (intermittent contact) but with your electronic reg that elims that. So I am thinking the alt if your idle speed is up high enough where it is supposed to be. On the high charging rate (which has to be dealt with) a sulphated battery would be the last potential but do continue to check voltage drops & jumping 12V to the reg "side" blue wire terminal would be my first step (a thin pin to stick in the triangle connector).
[Re: wally426ci]
#2409550
11/27/17 12:38 PM
11/27/17 12:38 PM
RapidRobert
If that is actually a voltmeter then that wiggle/slight raise you reported is normal. but 15+ is still a critical problem.
[Re: wally426ci]
#2414954
12/07/17 10:32 PM
12/07/17 10:32 PM
wally426ci
Maryland
Ugh. Baffled by high alt stud voltage reading. Had a new alternator on the bench so i swapped that in. New battery because the old was not holding charge. All of my voltage readings are very similar to first numbers posted (15.6 at alt stud)
Tried a new regulator for kicks with no change. Figured it was worth a try...
Alt wire goes straight to starter relay (madd style) could it be something in that neighborhood? Fusible link connections?
Starting problem cured with new switch. Volt gauge still pulses 12-13 volts
[Re: wally426ci]
#2414963
12/07/17 10:48 PM
12/07/17 10:48 PM
Supercuda
About to go away
About to go away
up yours
I've never used a volt gauge before this truck so I am not sure how they should be reading when tapping the full voltage at the gauges before the limiter..... Do you know how the IVR works? It's a clicker type regulator that uses the current passing thru it to heat up a bimetallic trip that cycles the load (gauges) on and off, you pick a poor source for your voltmeter as it is seeing that load clicking on and off. Did you ever get a reading at the voltage regulator sense voltage? I didn't see it in the thread. I suspect it is low.
[Re: wally426ci]
#2415162
12/08/17 12:14 PM
12/08/17 12:14 PM
Supercuda
About to go away
About to go away
up yours
You really want to check as close as possible to the VR. The sense line splits at the ballast so you would not be checking the feed to the VR at all.
If you followed Chrysler color codes the blue wire is the sense line, should be the same as the battery or alternator output voltage. The green line controls the alternator and you need to check each end and compare as that reading will vary depending on load.
[Re: wally426ci]
#2415201
12/08/17 01:24 PM
12/08/17 01:24 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
Do you still have the factory amp gauge?If it has one try disconnecting it.I had lots of problems with the ones in my trucks.Unhooked all and used a vot meter.That and Wells isnt the best brand for electronics.i use Standards etc.Rocky
Chrysler Firepower
[Re: wally426ci]
#2415859
12/09/17 07:45 PM
12/09/17 07:45 PM
wally426ci
Maryland
Ok, with the vr triangular plug at the bottom of the vr, i got the following readings:
Idle: top wire = 14.4 bottom right = 4.6 rev: top wire = 15.5 bottom right =13
Truck was wired without issue for a few years.
I did question myself after seeing a diagram that showed the ignition feeding from the lower vr terminal. Mine is fed from the top like other diagrams. I used jumpers to swap the field connections onnthe vr for a few minutes. I must have cooked that new vr because after that the alt stud readings held steady around 12.26 and the gauge in the truck was no longer reading.
So far i have not run seperate witing like Robert suggested as i wanted to report back first. In addition, i added an extra ground and cleaned the alt connections at starter relay. New positive bat cable since i had one.
[Re: wally426ci]
#2415895
12/09/17 09:04 PM
12/09/17 09:04 PM
Supercuda
About to go away
About to go away
up yours
Looks like the voltage sense is reading properly.
What does the ground for both the regulator and alternator look like? I'd run extra for testing.
Re: Over Charging Problem 68 Dodge Truck
[Re: wally426ci]
#2417064
12/11/17 11:44 PM
12/11/17 11:44 PM
RapidRobert
when the shop tested the alt did they give you a sheet with the voltage? which is what it produces when full fielded. You might try this: pull both female terminals off of the alt male field terminals & jump one terminal to the nearby alt case (ground) then hook the voltmeter to the alt (batt stud/nearby alt case) & idle it at a good fast idle & jump 12V to the other alt male field terminal for several seconds, just long enough to see what the voltmeter reads & have all lights/accessories OFF for this. Is this the same 15+V reading you are dealing with? You might also grab a coil of wire & some alligator clips from the HELP section at your parts house & make some jumpers & pull both field leads from the alt & pull the triangle reg connector & jump 12V to the top reg nub and 12V to either male alt field terminal then connect the other reg (side) nub only to the other alt male field terminal & jumper from the reg case to ground & start it & at a fast idle see what the voltmeter AT the alt reads. this takes the wiring out of the picture & only leaves the reg or the alt. & electronic regs almost always either go open (no charging) or full field (max voltage the alt can produce).
[Re: RapidRobert]
#2868130
01/02/21 03:30 PM
01/02/21 03:30 PM
wally426ci
Maryland
Happy New Year everyone. My charging issue has crept up again. Here is what I’ve done:
Truck was basically idle for a year or so with engine/trans build. Recently installed with good body grounds. Connections at firewall clean & snug. Fuse block cleaned. Truck runs well and would not notice this issue until 5 mins of driving or so.
Issue with previous charts as guide. I am trying to determine if this points to a particular component. Battery load tested well at a reputable battery shop. Squareback alternator with new style voltage regulator (triangular plug).
Readings (location, Idle voltage, 2500 rpm, engine off)
Battery positive terminal (12.16, 14.7, 12.53) Alternator stud (12.23, 19+, 12.53) Coil (10.36, 15+, 0) Top/center electronic VR terminal (11.27, 16+, 0)
+ sign means it was still climbing
Gauge, key switch and fuse block connections all clean & tight....
Greatly appreciate a bit of input.
[Re: Andrewh]
#2868155
01/02/21 05:44 PM
01/02/21 05:44 PM
RapidRobert
You might make up some jumper wires with alligator clips & jump each/all connections including grounds ALL BACK TO THE BATTERY & if normal then all the hard components are good & it is a positive or negative wiring/connector/ground issue. you might remove one at a time till the issue flares which pinpoints the problem. you might have to modify this procedure to suit but you get the jist of it. we gotta do some elimination. stay in touch (we got your back).
[Re: wally426ci]
#2868278
01/02/21 10:08 PM
01/02/21 10:08 PM
wally426ci
Maryland
Robert, when I jump, should I get a multimeter reading at the gauge each time? And I presume jumping coil/regulator?
[Re: wally426ci]
#2868297
01/02/21 10:50 PM
01/02/21 10:50 PM
RapidRobert
we're dealing with a charging issue so we will work on the charging components. jump from batt positive terminal to the top (blue wire) terminal on the reg (stick a thick pin/wire in to get continuity). jump from batt neg post to the reg case. pull the 2 wires off of the alt field terminals (dont let em touch ground). jump from one male alt field terminal to the battery positive terminal. jump the other alt field male terminal to the green wire in the reg connector (use a thick pin/wire). jump from the battery positive terminal to the large alt threaded stud. jump from the batt negative post to the alt case (you might use your jumper cables for this if they are secured good or have a helper hold them). fire it up to a fast idle & see what voltage you get at the battery. only have it running for a few seconds 10 or so (long enough to get a reading) as full fielding from a bad component/grounded wire will fry things in short order. have all lights/radio etc off. I dont think I missed anything. this elims everything except the alt/reg/battery. EDIT we could jump one at a time but that is too much full fielding. you might pull the alt brushes & a visual there, they are a frequent culprit. my gut says alt or reg
[Re: wally426ci]
#2869058
01/04/21 08:04 PM
01/04/21 08:04 PM
RapidRobert
Agreed I have never known an electronic reg to go back & forth. I'm thinking a connector or ground is losing/regaining continuity OR the brush assy in the alt is doing the same thing. Keep after it & keep us posted
[Re: RapidRobert]
#2869344
01/05/21 02:52 PM
01/05/21 02:52 PM
Posts: 19,355 north of coder
moparx
have you had the brushes out and closely examined the isolated brush holder ? what does the armature look like ? also, are the male connections to the brushes clean and tight ?
[Re: moparx]
#2869580
01/06/21 05:40 AM
01/06/21 05:40 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Have you tried remove the alt and spin by hand to check some friction, contact or weird feeling when spinning? May have not necessary remove the alt but just loose the belts and feel it.
I had once my alt giving up to 18volts at iddle ( more giving RPMs ) but no charge on ammeter ( some charge when giving RPMs ). One of the stator lead to diodes was making contact with just one of cooling vanes on rotor when spinning. Hard to feel but I was able to feel a small "stop" similar to the elect distributor stop due the magnet with reluctor points when spinning. Dissasembled, bent the wire a bit and done.
[Re: moparx]
#2869657
01/06/21 12:17 PM
01/06/21 12:17 PM
wally426ci
Maryland
have you had the brushes out and closely examined the isolated brush holder ? what does the armature look like ? also, are the male connections to the brushes clean and tight ? Good points all! I'm wallpapering this week, but will get back to it this Weekend.
[Re: wally426ci]
#2878010
01/21/21 06:56 PM
01/21/21 06:56 PM
wally426ci
Maryland
I appreciate everyone's help here. At the moment, I have a tentative fix (until I drive it more).
I double checked connections and grounds and did not find an issue. I kept thinking it was mechanical, because it would run fine for 5 minutes and almost switch to the high voltage. That told me it wasn't a connection.
I cleaned my Alt brushes and at the same time I replaced the VR. I am back to my original 14.7 idle to 14.5 readings at the gauge & across terminals/alternator, so I am hopeful that it was mainly the VR since the brushed looked fine to the eye. Keep ya'll posted (again)!
I have yet to jump anything, but I have that well documented in case this happens again.......
[Re: wally426ci]
#2879129
01/23/21 07:25 PM
01/23/21 07:25 PM
RapidRobert
what you might do if interested is unplug the reg & plug it into the old reg & ground the reg body with a jumper & see if it was the reg or the brushes
