Need Carb Build Help Please
#2407182
11/22/17 01:50 AM
11/22/17 01:50 AM
Posts: 487 St Louis, MO, USA
srunge55
St Louis, MO, USA
My friend gave me a Quick Fuel 950 carb with E85 metering blocks. I am planning on running gas so I need to replace the blocks. I was looking at the QF replacements blocks but not sure which ones to get. Do I need the same block on the front and back? Any advice greatly appreciated. I have been looking at these: https://www.summitracing.com/parts/qft-34-10qft/overview/Thanks, Steve
Re: Need Carb Build Help Please
[Re: srunge55]
#2407222
11/22/17 05:11 AM
11/22/17 05:11 AM
Posts: 43,123 Bend,OR USA
Cab_Burge
[Re: sgcuda]
#2407236
11/22/17 07:56 AM
11/22/17 07:56 AM
Posts: 4,457 Washington
madscientist
Washington
Check with Dominic Thumper. He has his own made by BLP. Think they already have lowered IFR's. And he can set you up with a calibration. ^^^^^^^^^^^^^This^^^^^^^^^^^^^^^^^ Dom can also help you to make sure no their changes are needed as cab pointed out.
[Re: srunge55]
#2407358
11/22/17 02:05 PM
11/22/17 02:05 PM
srunge55
St Louis, MO, USA
Thanks for the info. I'm not sure what "ifr's" are; I will do some research, call QF and look into the BLP blocks. I talked to my friend and its a gas center and he added e85 blocks so the boosters should be gas. It probably didn't run good so that is why he gave it to me :-). Its this main body (actually a Proform): https://www.summitracing.com/parts/pro-67108cThanks again, Steve
[Re: srunge55]
#2407365
11/22/17 02:30 PM
11/22/17 02:30 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'd get the 34-105 kit which comes with a pair of blocks.
Several years ago I built a few "HP750's" out of the original ProForm bodies. Back then I just used std metering blocks for a Holley 4779(750dp), along with std base plates. Those carbs worked pretty well....... So I thought I'd do another one with the new style parts. I used the Holley HP body for this one, along with the aluminum qft bowls, billet baseplate, and the 34-105 metering block kit.
Unfortunately, I haven't run it on anything yet, so I can't comment on the performance.
[Re: Thumperdart]
#2407372
11/22/17 02:49 PM
11/22/17 02:49 PM
madscientist
Washington
The boosters MAY need to be changed as well but not 100% till you either ask QF or measure em yourself and if that's the case, I'd sell it and get what you need or someone can build to you needs............ As far as BLP building the blocks w/lower ifr's, Mark W I believe pushed em in that direction and I buy a bunch so now they whip em up for who ever likes those changes.......... I must be the only guy who can't my junk to run with the IFR's down low. My car hates the IFR's low. I've tried it many times and I can never make it happy with them down.
[Re: srunge55]
#2407377
11/22/17 02:53 PM
11/22/17 02:53 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
you will also need to change the air bleeds (idle and high speed) on the main body...they are different size went using e85 compared to gas.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: srunge55]
#2407443
11/22/17 05:05 PM
11/22/17 05:05 PM
fast68plymouth
So. Burlington, Vt.
The qft blocks have the ifr in the upper position. I wouldn't worry about moving them until you determine your combo can't seem to be made to run right with them in the upper position.
[Re: srunge55]
#2407455
11/22/17 05:20 PM
11/22/17 05:20 PM
madscientist
Washington
thanks for the explanation. I would probably benefit from lowered IFRs. Are there any general rules on IFR settings based on vacuum levels? I have ~8 inches of vacuum at idle and my carb doesn't like low IFR's. I've never been able to nail it down but I'm assuming the low idle vacuum wants high IFR's. I'm sure Dom and Mark have better thoughts on it than I do.
