Will these wheels fit my 2013 Ram? #2400164
11/07/17 09:06 PM
11/07/17 09:06 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
I don't know if the backspacing changed. They came off of a 2008 Ram 1500.
https://m.ebay.com/itm/RAM-2006-2007-2008-Factory-Alloy-Rim-5-Five-Spoke-OEM-20x9-Wheel-Argent-Finish/182718358278?hash=item2a8adce306:g:a0EAAOSw1aFZkzXu
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Will these wheels fit my 2013 Ram? [Re: roe] #2400475
11/08/17 01:46 PM
11/08/17 01:46 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
I have no hands on experience, but I believe the bolt pattern is the same, and back spacing is the same, but in 09 (I believe) they started using metric size/thread lugs, along with a different lug nut seat shape.
I don't know if "combo" or adapter style lugs are available or even practical.
I have some of the earlier wheels, and a '14 truck, I should pull the wheels ...
If you are thinking of buying these, Craigslist is your friend. I am going to upgrade my 14 with some 20", but am looking at the current styles.
It takes gasoline to interest me.
Re: Will these wheels fit my 2013 Ram? [Re: VL21] #2403300
11/13/17 11:51 PM
11/13/17 11:51 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
I was just linking to the eBay ad to show the picture. A buddy is offering me his set for $200. I was hoping I could bolt them on and go. Maybe get those and a set of the aftermarket lug nuts from the parts store? Or swing by the dealer and see what they say once I have the wheels in hand
Re: Will these wheels fit my 2013 Ram? [Re: roe] #2403328
11/14/17 12:37 AM
11/14/17 12:37 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I have a set of '15 Ram Sport 20's on my '05 Ram (originally had 20's as well) so I don't see the rims not fitting in your situation. Everything was perfect, bolt patter, offset, even used my old wheel nuts
Re: Will these wheels fit my 2013 Ram? [Re: WO23Coronet] #2405804
11/19/17 03:47 AM
11/19/17 03:47 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Thanks. That's what I was hoping for. I thought they should work but wanted to make sure nothing changed that I didn't know of
Re: Will these wheels fit my 2013 Ram? [Re: roe] #2406935
11/21/17 06:08 PM
11/21/17 06:08 PM
dogdays Offline
dogdays  Offline
Did you know that you can usually find wheel dimensions on the Rockauto website? It's my online lending library.
In the case of 2008 and 2013 1500s, the 20" wheels have exactly the same dimensions.
R.
Re: Will these wheels fit my 2013 Ram? [Re: dogdays] #2409107
11/26/17 02:08 PM
11/26/17 02:08 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
I didn't, but I do now. I'm goingb to have to remember that for next time. up
