My used Eagle heads...on the bench, as delivered. #2313359
05/30/17 01:27 AM
05/30/17 01:27 AM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
First Gen 3 parts I've ever owned, tossed them up on a flow bench today. Untouched, completely stock, as far as I can tell. Testing on a 4.00" bore. Wow...
259 @ .400
267 @ .450
271 @ .500
286 @ .550
292 @ .600
298 @ .650
301 @ .700
The big surprise was the valve springs. Could these be stock??
126# closed at installed height
350# at .550 open
Looks they are done at .585, but seems pretty stout for an OE spring.
Re: My used Eagle heads...on the bench, as delivered. [Re: cudadoug] #2313388
05/30/17 02:51 AM
05/30/17 02:51 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Your numbers are a little lower than what most of us get. Most of us have hit 300 by .5 and stays the same at .6
Ive went rounds before over the valve springs. When i tested them, the pressures were better than pac 1218s i think i had at the time.
Re: My used Eagle heads...on the bench, as delivered. [Re: cudadoug] #2313525
05/30/17 01:10 PM
05/30/17 01:10 PM
cudadoug Offline OP
cudadoug  Offline OP
I did leave out one detail. The radius entry wasn't a good match with the port, so once that's done we should see better numbers. But overall, I was stoked to SEE those numbers. I've heard of and read the hype, but in many years gone by we've worked real hard to get alot less numbers from old school heads.
Re: My used Eagle heads...on the bench, as delivered. [Re: cudadoug] #2313645
05/30/17 04:46 PM
05/30/17 04:46 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Seeing what the heads are capable of was one of the big reasons I jumped off the BB ship. IMO opinion they are the best engines to use in a NA 600-700hp pump gas application period.
Mopar to the bone!!!
Re: My used Eagle heads...on the bench, as delivered. [Re: cudadoug] #2313691
05/30/17 05:50 PM
05/30/17 05:50 PM
cudadoug Offline OP
cudadoug  Offline OP
QUOTE: Ive went rounds before over the valve springs. When i tested them, the pressures were better than pac 1218s i think i had at the time.
Yes, the PAC 1218 is 130/318.
Re: My used Eagle heads...on the bench, as delivered. [Re: cudadoug] #2314032
05/31/17 03:10 AM
05/31/17 03:10 AM
cudadoug Offline OP
cudadoug  Offline OP
New entry radius that fits...
299 @ .500
303 @ .550
312 @ .600
313 @ .650
Re: My used Eagle heads...on the bench, as delivered. [Re: cudadoug] #2314509
06/01/17 11:29 AM
06/01/17 11:29 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Originally Posted By cudadoug
259 @ .400
350# at .550 open
done at .585 ...Coil bind or clearance ?
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: My used Eagle heads...on the bench, as delivered. [Re: ric3xrt] #2314531
06/01/17 12:24 PM
06/01/17 12:24 PM
cudadoug Offline OP
cudadoug  Offline OP
259 @ .400
350# at .550 open
Coil bind.
Re: My used Eagle heads...on the bench, as delivered. [Re: cudadoug] #2314897
06/01/17 11:52 PM
06/01/17 11:52 PM
SoCal
Brian Hafliger Offline
SoCal
299 @ .500
303 @ .550
312 @ .600
313 @ .650
Yep, with slightly larger valves, multi angle valve job, bowl cleanup and port massage they will go mid 330's real easy...and as much as 319@ .500 lift!
Easy stuff!!
Brian Hafliger
Re: My used Eagle heads...on the bench, as delivered. [Re: cudadoug] #2315707
06/03/17 08:39 PM
06/03/17 08:39 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
What's the biggest lift you can get with stock length valves? What springs will do the job? Specs?
Re: My used Eagle heads...on the bench, as delivered. [Re: cudadoug] #2320870
06/13/17 11:42 PM
06/13/17 11:42 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
Bump
Re: My used Eagle heads...on the bench, as delivered. [Re: Medlock51] #2321394
06/15/17 12:44 AM
06/15/17 12:44 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
650 is about max with stock rockers. For eagle head alot are using psi1511 or 1515
Re: My used Eagle heads...on the bench, as delivered. [Re: sixpackgut] #2321800
06/15/17 09:11 PM
06/15/17 09:11 PM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
How much lift (custom cam) could be run with eagle or apache head by locking cam straight-up? (on an oem takeout motor)
Re: My used Eagle heads...on the bench, as delivered. [Re: cudadoug] #2322196
06/16/17 04:03 PM
06/16/17 04:03 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Re: My used Eagle heads...on the bench, as delivered. [Re: cudadoug] #2406204
11/20/17 02:49 AM
11/20/17 02:49 AM
cudadoug Offline OP
cudadoug  Offline OP
Back at playing with these. Holy smokes...we're not even porting just smoothing what is there and trying different valve jobs...
.550 = 311 cfm
.600 = 321
.650 = 326
Wow. Sorry but I'm late to the G3 party so...WOW!
Re: My used Eagle heads...on the bench, as delivered. [Re: cudadoug] #2406286
11/20/17 12:18 PM
11/20/17 12:18 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
.550 = 311 cfm
.600 = 321
.650 = 326
Been saying it for years!!!
Dollar for dollar you CANNOT beat the g3 layout.
Easy to make power at a much lower stress engine level.
BIGGEST thing is the availability of cheap parts!
Matt
