Look at last picture. See the single finger to the inside? You need to pry that out slightly from the metal while lifting up on the whole fuzzy unit. Once it lifts up a small amount then go to the next clip and do the same.
Don't pry from the top side on the shiny side, you will scratch the paint and put waves in the straight stainless piece.
Alot easier to learn on that part before doing it on the car where you can't see what's happening and less room to work. You should be able to get them off with no damage. It is much more difficult when the clips are rusted to the metal.
