4 speed bell crank bushing problems
#2405902
11/19/17 01:38 PM
11/19/17 01:38 PM
Posts: 482 Marysville Wa
moparfan
Marysville Wa
I've replaced the nylon bushings in the bell crank twice now. Both times they have split in the groove cut into them. The car has the original bell crank etc. I did replace the clutch with a borg and beck factory replacement from Ramm. Any ideas?
I should add it seems to be fine until I speed shift the car.
2017 Challenger R/T Scat Pack Shaker 2021 T/A 392 1970 Challenger R/T 383,727, 3.55, (Wife's car) 1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana 1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85 2020 Hellcat redeye
Re: 4 speed bell crank bushing problems
[Re: moparfan]
#2405942
11/19/17 03:08 PM
11/19/17 03:08 PM
Posts: 18,153 Mass
DAYCLONA
Mass
I should add it seems to be fine until I speed shift the car. I went thru this using the Mopar/aftermarket replacement bushings, at first I thought lubrication was the issues, but it was poor quality mat'l after going thru several sets, I located a used/original set and solved the issue
[Re: DAYCLONA]
#2405979
11/19/17 04:45 PM
11/19/17 04:45 PM
moparfan
Marysville Wa
I'm using the mopar after market ones and assume that's the issue. The groove appears to be an issue. Both have split in the groves.
