Page 3 of 3 1 2 3
Re: Broke my K Frame [Re: Kern Dog] #2420427
12/18/17 05:19 PM
12/18/17 05:19 PM
California
mickm Offline OP
mickm  Offline OP
California
Ok, so got it out. I think the pictures below explain it all. I think my repair job will hold up just fine, let me know what you think.
I think this is supposed to be attached.
Everyone knows black duct tape is superior to the standard silver tape, so I think I got this covered.
Best part about it, it blends right in, so I don't even have to repaint!
Re: Broke my K Frame [Re: mickm] #2420431
12/18/17 05:28 PM
12/18/17 05:28 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Nice job, Mick! Personally, I would have used a generous bead of super glue prior to applying the duct tape. But that might be overkill...
Re: Broke my K Frame [Re: mickm] #2420434
12/18/17 05:29 PM
12/18/17 05:29 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
is there something weird going on with your LCA pivot tube? the weld looks strange.
Re: Broke my K Frame [Re: krautrock] #2420497
12/18/17 06:37 PM
12/18/17 06:37 PM
California
mickm Offline OP
mickm  Offline OP
California
Yes, I noticed that as well. We will be going over the whole k frame, looking for any other issues, so I'll definitely take a closer look at that.
Re: Broke my K Frame [Re: Fat_Mike] #2420499
12/18/17 06:38 PM
12/18/17 06:38 PM
California
mickm Offline OP
mickm  Offline OP
California
Yeah, I think so. The engine only puts out 700hp, duct tape should handle that! up
Re: Broke my K Frame [Re: mickm] #2420501
12/18/17 06:38 PM
12/18/17 06:38 PM
California
mickm Offline OP
mickm  Offline OP
California
But seriously folks, ee are going to repair it. It is truly amazing, just how bad these welds were from the factory and that it lasted this long. I thought about which way to go, and with the above fact, terrible welds and still it lasting as long as it did, I don't have any doubts that welded properly it will be good from here on out. We are going to go over the rest of the k frame and redo welds that don't look good as well.
Re: Broke my K Frame [Re: mickm] #2420720
12/19/17 12:36 AM
12/19/17 12:36 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
From what I can tell the welder missed most of the mount perch. I picked up an A-body k-member where they forgot to weld in one of the strut rod reinforcement plates. The body of the k-member cracked behind it.
Re: Broke my K Frame [Re: Jim_Lusk] #2420761
12/19/17 01:46 AM
12/19/17 01:46 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I've seen messed up control arm tubes before, they can be tricky to weld.
Sheldon
Re: Broke my K Frame [Re: RUNCHARGER] #2421278
12/20/17 01:41 AM
12/20/17 01:41 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The last few k-members that I have done I have cut the bottom open below the pin tubes and welded from the inside. Might also make sense to open the top and weld it from the top, too.
Re: Broke my K Frame [Re: Jim_Lusk] #2421939
12/21/17 05:46 PM
12/21/17 05:46 PM
California
mickm Offline OP
mickm  Offline OP
California
I'm hoping it doesn't come to that. If so, may be worth just finding another one. I'm hoping to have it back from the powder coating guys, (burning the old stuff off), soon, and then we can really go over it.
Re: Broke my K Frame [Re: mickm] #2422170
12/22/17 01:45 AM
12/22/17 01:45 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I do it as a preventative measure. I'm not sure about your k-member, but the tubes did not receive much of a weld on one end on A-bodies. Here's a pic. I actually split this K-member so that I could straighten it. In part just to see if I could...
Re: Broke my K Frame [Re: RUNCHARGER] #2422327
12/22/17 03:23 PM
12/22/17 03:23 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
That car is a beast! Does it already have subframe connectors in it and the front frame rails tied together?
Re: Broke my K Frame [Re: jbc426] #2422346
12/22/17 04:28 PM
12/22/17 04:28 PM
California
mickm Offline OP
mickm  Offline OP
California
I have the US Cartool connectors, the ones that are welded all along the bottom of the floorpan. It makes a big difference!
Re: Broke my K Frame [Re: mickm] #2428161
01/03/18 04:02 AM
01/03/18 04:02 AM
California
mickm Offline OP
mickm  Offline OP
California
So, here is the latest. The K frame is all welded up and ready to go. We tacked the perch on, and then I did a test fit, and it was perfect, so we finished off the welding.
I decided to stick with this (instead of going for a MegaParts hemi K frame, I have the Schumacher mounts), for the following reason. When you look at the photos, you will see how ungodly horrific the welds that held this perch on were. It's absolutely astonishing to me that as bad as these welds were, that the thing lasted this long. The welds along the seams that make the perch itself are very, very nice welds, so no worry at all there. When you compare what was there before, and what is there now, I have full confidence that it will outlive me!
I also put the FirmFeel braces on the LCA's, a few pictures of those.
We also reinforced a number of other areas on the K frame. Some welds I ground away and we redid, and some we just added in places that can only help. Pictures should say everything.
This is where the perch was welded on the top. You can see that the weld barely penetrated the metal of the perch.
This is along the side. Again, astonishing these held as long as they did.
A zoomed out shot.
Control arm with FirmFeel brace.
Re: Broke my K Frame [Re: mickm] #2428163
01/03/18 04:06 AM
01/03/18 04:06 AM
California
mickm Offline OP
mickm  Offline OP
California
More pics:
The top of the steering box mount. This is from the factory, (minus my cleaning it up).
Whoops! A split in the metal. Don't know if that has been there, or was caused by the latest incident.
The perch, with new welds.
Re: Broke my K Frame [Re: mickm] #2428164
01/03/18 04:08 AM
01/03/18 04:08 AM
California
mickm Offline OP
mickm  Offline OP
California
And the last few:
A few additional welds.
The mess on top of the steering box mount cleaned up.
The split welded up.
Re: Broke my K Frame [Re: mickm] #2428244
01/03/18 12:52 PM
01/03/18 12:52 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
WOW, some of those factory welds look like my doing!
But, I swear, I was nowhere near the the factory back then, Iowa at the time, in college.
Sooo, my welds WOULD have looked like that ...
It takes gasoline to interest me.
Re: Broke my K Frame [Re: VL21] #2428278
01/03/18 02:00 PM
01/03/18 02:00 PM
California
mickm Offline OP
mickm  Offline OP
California
It is scary how bad some of them were. Especially that perch. The guy knew that this was holding the engine in place, but hey, good enough, I guess...
I didn't show any pictures of the before on some of the others, but pretty bad. Hard to believe someone was hired with that lack of a skillset.
Re: Broke my K Frame [Re: mickm] #2428499
01/03/18 09:30 PM
01/03/18 09:30 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
That looks much better. Great job
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Broke my K Frame [Re: mickm] #2428516
01/03/18 09:51 PM
01/03/18 09:51 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I've seen more sloppy welds on k-members than on about anything else.
Page 3 of 3 1 2 3
