B&M flex plate question #2405007
11/17/17 03:14 PM
11/17/17 03:14 PM
midwest
superchuck Offline OP
On thin ice
On thin ice
midwest
With a 360 and using a B&M flexplate, do I need to have the weight welded to the convertor? Here is the flex plate in question.
https://www.summitracing.com/parts/bmm-10239/overview/
Re: B&M flex plate question [Re: superchuck] #2405015
11/17/17 03:33 PM
11/17/17 03:33 PM
A727Tflite Offline
A727Tflite  Offline
No weight. Read the testimonials in the ad from Summit. The cutout on he B & M should be 180 degrees from the weight on a production flexplate.
Re: B&M flex plate question [Re: superchuck] #2405077
11/17/17 05:17 PM
11/17/17 05:17 PM
midwest
On thin ice
On thin ice
midwest
I read them, just wanted to make sure.
Re: B&M flex plate question [Re: superchuck] #2405123
11/17/17 06:53 PM
11/17/17 06:53 PM
A727Tflite Offline
A727Tflite  Offline
You'll be good with this plate. Bolt her up and let her rip.
