Re: indy max block oiling [Re: RylisPro] #240494
03/02/09 06:41 PM
03/02/09 06:41 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
The main thing I was looking for is if any one tried drilling out the holes in the block or slotting them and did it help for drain down. I was thinking of drilling a couple holes in the front where the stock block is open to the front where the distributor is to give it a place for it to draw air from the vac pump and that might help the oil to drain down easier.
Re: indy max block oiling [Re: plycuda] #240495
03/02/09 07:28 PM
03/02/09 07:28 PM
PA
joez Offline
joez  Offline
PA
Weston Machine in NJ can drill the block for pushrod oiling. I don't remember how much it was, but it was fairly expensive. They have to plug all the lifter bores so the drill doesn't wander, then remove the plugs and bush the bores.
I drilled and tapped mine and made a manifold and never had any problems.
Re: indy max block oiling [Re: joez] #240496
03/02/09 07:39 PM
03/02/09 07:39 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
weston is one of the ones lee edwards told me to call because they do some of his block work and the guy said he used to do it but he won't do it any more he said it was to much of a pain because of plugging all the lifter bores.
Re: indy max block oiling [Re: plycuda] #240497
03/02/09 10:18 PM
03/02/09 10:18 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Thats what I did with the front but I think I am going to do the heads or the back of the valley this year with an lines. For the most part our sport is forward motion.
