Re: indy max block oiling
[Re: boatracer572]
#240478
03/01/09 11:16 PM
03/01/09 11:16 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Many, many seasons with spray bars, no problems, a friend of mine has been running them at least 5 years longer than me, never replaced a single valve train part. No need to drill the lifter bores for this. I do suggest running ball/ball end push rods though. And have cup adjusters..
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: boatracer572]
#240480
03/01/09 11:28 PM
03/01/09 11:28 PM
Bob_Coomer
Rock Springs
Valve springs will be the last thing to burn up from lack of oil.... I ran spring pressures, near 800lbs open pressure. IMO I don't see a bunch of extra heat coming off the valve springs due to more spring pressure. If anything gets burnt up, it will be the little parts in the top, push rod cups, adjusters etc. I know personally 4-5 guys running the Jesel stuff with zero problems besides me. Just stating my experiences..
[Re: boatracer572]
#240481
03/01/09 11:56 PM
03/01/09 11:56 PM
Posts: 778 Sherwood park, Alberta.
go green
You may have a problem burning up pushrods with the spray bars!you could build a oil manifold with brake line and drill and tap every lifter bore to pushrod oil! I have seen It done many times before!
Like this.
[Re: go green]
#240483
03/02/09 12:21 AM
03/02/09 12:21 AM
Posts: 795 Glendale Az
Darryls-Demon
Glendale Az
Like this.
Yikes, I want to switch my Indy block to push rod oiling. Is this the only way to do it?
[Re: go green]
#240485
03/02/09 07:42 AM
03/02/09 07:42 AM
Posts: 8,180 Detroit, MI
CokeBottleKid
Detroit, MI
Like this.
Wow that's alot of hassle for pushrod oiling
[Re: ts racer]
#240486
03/02/09 09:10 AM
03/02/09 09:10 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I agree with TS, spray bars work just fine. Use quality parts, pay attention to detail and everything works just fine. If I had to maniflod/plumb a block like that, I'd just have it drilled out. Thats a lot of work, but I am sure it works.
RIP Monte Smith
[Re: B G Racing]
#240489
03/02/09 12:22 PM
03/02/09 12:22 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
Why not just drill the block for hydraulic lifter oiling?It's the same as stock oiling.
Didn't even know there was a difference, please explain, because my last one ate evry push rod I put in it.
[Re: plycuda]
#240493
03/02/09 06:36 PM
03/02/09 06:36 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
I called a bunch of machine shops and all of them said they can't do it. after talking to indy like I said they will not get any of my money.
I wouldn't let the best heart surgeon operate on me if I didn't like his attitude either.
