#2404703 - 11/16/17 08:44 PM 318 to 360
Crizila Offline
Loc: Az
I want to replace a very tired 318 from a 97 truck with a 360, using all the 318 components - computer and fuel injection electronics. Can this be done without any issues? Thanks, John
Fastest 300
#2405230 - 11/17/17 08:40 PM Re: 318 to 360 [Re: Crizila]
poorboy Offline
Loc: Freeport IL USA
You will have to change the torque converter/flywheel from the 318 to the 360 for the 360 balance.
Unless you push your truck to the extremes, the 318 stuff will run the 360. If you really push it, at the higher rpm range, I suspect the 318 stuff could run a little lean for the 360, but for normal driving it should be OK. Gene
#2405235 - 11/17/17 08:50 PM Re: 318 to 360 [Re: Crizila]
Supercuda Offline
Generally, the stock tune on the Magnums is pretty rich at WOT, you might find it runs better with a 5.9 in place.
#2406323 - 11/20/17 10:50 AM Re: 318 to 360 [Re: Crizila]
savoy64 Offline
Loc: colorado
also the crank damper needs changed.....
#2406496 - 11/20/17 05:04 PM Re: 318 to 360 [Re: Crizila]
Crizila Offline
Loc: Az
Thanks guys! bow
Fastest 300
#2414026 - 12/05/17 11:03 PM Re: 318 to 360 [Re: Crizila]
CrAzYMoPaRGuY Offline
Loc: Canada
I believe the passenger side motor mount needs to be played with a bit unless I am mistaken? 3/8" to 1/2" of shims on a bolt or two?
CrAzYMoPaRGuY
25,344 Registered Members
190,215 Topics
Most users ever online: 1,424 @ Yesterday at 07:18 PM
'67 GTX for $23K What's it worth?
by VITC_GTX
Yesterday at 11:51 PM
Going to look at 09 Journey
by chargers777
Yesterday at 09:50 PM
Who's the Spring guy?
by fullmetaljacket
Yesterday at 08:45 PM
Putting a deposit on a car?
by EV2Bird
Yesterday at 08:44 PM
