#2379639 - 09/30/17 09:59 PM Parts For Sale - Classic/Streetrods - 4th Quarter
moparts Offline
#2387199 - 10/14/17 01:16 AM Re: Parts For Sale - Classic/Streetrods - 4th Quarter [Re: moparts]
kdsmith07 Offline
Loc: Loganville GA.
61 dodge pass.car hood like dart seneca phoenix & polara.also fit's 62 880 series.stripped to bare metal and is 100% rust free with only a few dings.corners are perfect.really nice hood.asking 200.00 and pick up in ga.30052.pm me or call or text 678-542-9138 if interested,thanks
#2390915 - 10/21/17 04:00 PM early hemi 1642392 dual point distributor [Re: kdsmith07]
Rapid340 Offline
Loc: oberlin, Ohio
early hemi 1642392 factory prestolite dual point distributor
$95 plus shipping
jeffpatterson@copper.net
331 354 392
Jeff Patterson 71 Duster 340, Factory Appearing
11.000 122.3 MPH on 6 in. M&H Volkswagen tires.
Intelligence? http://www.youtube.com/watch?v=cpM76ymlnbA
#2390916 - 10/21/17 04:07 PM 354 Early hemi OEM 1409421 forged crankshaft [Re: Rapid340]
Rapid340 Offline
Loc: oberlin, Ohio
super nice condition
mains std
rods .010
pics available
$385 plus shipping
331 354 392 poly
#2390922 - 10/21/17 04:30 PM 303 313 326 318 OEM forged poly crankshaft [Re: Rapid340]
Rapid340 Offline
Loc: oberlin, Ohio
This is the early one similar to hemi with long rear journal.
mains std, rods std
$285 plus shipping
thanks
331 354 392 poly
#2403822 - 11/14/17 11:03 PM Re: 303 313 326 318 OEM forged poly crankshaft [Re: Rapid340]
Joesixpack Offline
Loc: APACHE JUNCTION AZ
NORS/NOS USA MADE TUNE UP PARTS
INCLUDES A BRASS INSERT,HD,RIBBED,TALL COIL WIRE TOWER,CARBON BRUSH EQUIPPED ECHLIN DISTRIBUTOR CAP.
A NOS AUTOLITE IGNITION ROTOR
A NOS MOPAR CONDENSER #1818757
A PAIR OF DUAL POINTS
3 INTERNAL DISTRIBUTOR WIRE LEADS
WILL FIT ;
1956 -1957-1958 CHRYSLER NEW YORKER,IMPERIAL,300 DUAL POINT DISTRIBUTOR'
1956 DESOTO FIREDOME,FIREFLITE,DODGE WITH IBJ-4301A DIST,PLYMOUTH,CHRYSLER WINDSOR WITH SINGLE POINT DISTRIBUTOR(DIFFERENT LEADS ARE USED, I CAN EXCHANGE THEM FOR CORRECT ONES)
THE SINGLE POINT DISTRIBUTOR IN 1956 USES THE SAME POINTS SET AS DOES THE 56-57-58 DUAL POINT. THEY JUST USE 1 SET INSTEAD OF 2
1957 PLYMOUTH WITH DUAL POINT DISTRIBUTOR #IBS-4003
IF YOU ARE NOT SURE ABOUT FITMENT, GIVE ME YOUR AUTO-LITE DISTRIBUTOR TAG# TO CONFIRM
$35
cowgerwilliam035@gmail.com
#2403823 - 11/14/17 11:05 PM Re: 303 313 326 318 OEM forged poly crankshaft [Re: Joesixpack]
Joesixpack Offline
NORS GENERATOR BUSHING&A NOS AUTO-LITE GGY-2012S BRUSH SET , WILL FIT;
1956-1957-1958-1959-1960 CHRYSLER& DESOTO WITH GJC,GJM,TAG#GENERATORS
THERE ARE AROUND 6 DIFFERENT GENERATORS USED IN THE ABOVE YEARS, THEY HAVE DIFFERENT BRUSHS AND DIFFERENT BUSHINGS, IF YOU WANT TO BE 100% CORRECT GIVE ME YOUR AUTO-LITE GENERATOR TAG# TO CONFIRM FITMENT. DONT BUY THESE A WISHING AND A HOPING THEY WILL FIT AND BE MAD WHEN THEY DONT BECAUSE WE DID NOT CHECK FIRST.OK?$10
#2403825 - 11/14/17 11:07 PM Re: 303 313 326 318 OEM forged poly crankshaft [Re: Joesixpack]
Joesixpack Offline
1939 CHRYSLER,DESOTO,DODGE
2 DOOR LOCK LATCH SPRINGS(UPPER)
2 DOOR LOCK LATCH SPRINGS(LOWER)
2 DOOR LOCK LATCH SPRINGS(LOWER,SIDE)
2 TRIPLE CAM SPRINGS
2 REMOTE CONTROL SPRINGS
2 TENSION SPRINGS
4 KEEPERS $40
#2403826 - 11/14/17 11:09 PM Re: 303 313 326 318 OEM forged poly crankshaft [Re: Joesixpack]
Joesixpack Offline
NORS GENERATOR BUSHING&A BRUSH SET , WILL FIT;
1937-1938-1939-1940-1941-1942&1946-1947-1948 CHRYSLER $10
#2403829 - 11/14/17 11:12 PM Re: 303 313 326 318 OEM forged poly crankshaft [Re: Joesixpack]
Joesixpack Offline
2 NOS MADE IN THE USA AUTO-LITE IAT-1033 6CYL COPPER INSERT HD DISTRIBUTOR CAPS,WITH AUTO-LITE LOGO ON TOP AND THE # INSIDE, 2 NOS MOPAR 1343587 IGNITION ROTORS. WILL FIT 1950-1951-1952-1953-1954-1955-1956-1957-1958-1959 DODGE&PLYMOUTH FLATHEAD 6$45
cowgerwilliam035@comcast.net
#2403830 - 11/14/17 11:15 PM Re: 303 313 326 318 OEM forged poly crankshaft [Re: Joesixpack]
Joesixpack Offline
NORS STARTER BUSHINGS(2)AL259&AL264 D.E.,C.E.,&A BRUSH SET , WILL FIT;
1949-1953 CHRYSLER,1949-1953 DESOTO,1949-1953 DODGE,1949-1953 PLYMOUTH ,1948-1952 FARGO$15
#2403955 - 11/15/17 10:56 AM Re: 303 313 326 318 OEM forged poly crankshaft [Re: Joesixpack]
Joesixpack Offline
USA MADE NORS BRAKE LIGHT SWITCH, TUNGSTEN SLS-22,WILL FIT;
1939-1941&1949-1952 CHRYSLER
1939-1941&1950-1951-1952 DODGE
1940-1941&1952 DESOTO
1940-1952 PLYMOUTH
$12
#2403956 - 11/15/17 10:57 AM Re: 303 313 326 318 OEM forged poly crankshaft [Re: Joesixpack]
Joesixpack Offline
1956-1957-1958-1959-1960 CHRYSLER& DESOTO WITH GJC,GJM,TAG#GENERATORS$12
#2414298 - 12/06/17 02:27 PM Re: 303 313 326 318 OEM forged poly crankshaft [Re: Joesixpack]
Joesixpack Offline
WILL FIT ;
IF YOU ARE NOT SURE ABOUT FITMENT, GIVE ME YOUR AUTO-LITE DISTRIBUTOR TAG# TO CONFIRM$35
#2415337 - 12/08/17 03:05 PM Re: 1956 Chrysler Newyorker [Re: Joesixpack]
36PLYM Offline
Loc: Lithonia, Ga
Auto trans and converter from 1956 Newyorker, was behind 354 Hemi. Hemi is not for sale! $200 OBO, local pickup in the Atlanta metro.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
25,067 Registered Members
185,576 Topics
Exhaust leak ??
by Jupiter331
01/16/18 03:30 PM
INDY 440-3RB VS INDY 440-2RB WITH 440-2A 2" RISER
by moparjohn
01/16/18 03:01 PM
M Code Lug Nuts
by hemiviper588
01/16/18 03:01 PM
Tire Size55
by Crabra
01/16/18 02:37 PM
