Small block Timing Chain tensioneer help?
#2403811
11/15/17 01:29 AM
11/15/17 01:29 AM
Posts: 1,043 Motown, Mi
PAULS_340
Motown, Mi
Does a tensioner have any drawbacks?
Still looking for LM29H1B415501, '71 Demon 340
Re: Small block Timing Chain tensioneer help?
[Re: PAULS_340]
#2403958
11/15/17 02:05 PM
11/15/17 02:05 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Pretty sure a tensioner on a rollmaster timing set was belt and suspenders thinking.
Factory used them for a reason, almost no one here, myself included, is using it for the same reason. I am using one because it has been my experience that today's timing chains go slack too fast. tired of timing chain replacements on a yearly interval.
[Re: PAULS_340]
#2404016
11/15/17 04:13 PM
11/15/17 04:13 PM
Supercuda
About to go away
About to go away
up yours
I understand, I'm doing similar but running an Edelbrock timing set, had great luck with those over the years.
[Re: PAULS_340]
#2404531
11/16/17 04:22 PM
11/16/17 04:22 PM
Posts: 4,366 Michigan
MarkZ
Worthy
Worthy
I ran one when I still had a 360. You could certainly feel the difference in the chain tension after installing it. Took it apart after 20k for a leak and it was still as tight as the day I installed it.
