Re: are oversize hyd lifters available? 360 SB
[Re: RapidRobert]
#2421785
12/21/17 11:13 AM
12/21/17 11:13 AM
Posts: 6,089 Valencia, España
NachoRT74
Valencia, España
Rapid Robert, you got your inbox full... I'm trying to get a conversation between you, me and fullonmopar to work on this
[Re: RapidRobert]
#2421806
12/21/17 12:19 PM
12/21/17 12:19 PM
NachoRT74
Valencia, España
Damn! still getting same message
[Re: NachoRT74]
#2421822
12/21/17 01:04 PM
12/21/17 01:04 PM
RapidRobert
I'll go delete a bunch more. EDIT Now try it
[Re: RapidRobert]
#2427673
01/02/18 12:20 PM
01/02/18 12:20 PM
NachoRT74
Valencia, España
3004648 are BB which got the oil groove higher ( 976 replacement part ). Remember I'm BB owner, but I can take SB pieces ( 2011 replacement PN ) because they work on BB, not the other way around thought. I'm actually running HLJ SB pieces on my BB, because for whatever reason the BB HLJ never got charged. MAYBE is because the lifter bores are worn out somehow conical and the higher oil groove doesn't help?!!! Sooo maybe running OS BB lifter will work. The problem is the machine shop hasn't taken my block yet to measure it!
[Re: RapidRobert]
#2428765
01/04/18 10:22 AM
01/04/18 10:22 AM
NachoRT74
Valencia, España
Good!
I still dunno if the local one will be able too either.
If the web seller I found got them in .001 maybe will be enough! Is hard to imagine how much is .001" but on this deal it seems to be a HUGE difference. Just opened my caliper at that gap and is really noticeable. So .001" should be enough
[Re: RapidRobert]
#2428984
01/04/18 05:21 PM
01/04/18 05:21 PM
NachoRT74
Valencia, España
but I'm working on get BB ones if posible
HOWEVER I can request an extra for SB on same deal... that is if the deal works out. So far so good I just have got one reply from them asking for more info and if will be an inmediate buy or a bid ¿?¿?¿?¿?¿?¿?¿?¿?¿?¿
[Re: RapidRobert]
#2429060
01/04/18 06:59 PM
01/04/18 06:59 PM
crabman173
crabman173
Jim at Racer Brown has them call him
[Re: RapidRobert]
#2429218
01/04/18 10:45 PM
01/04/18 10:45 PM
NachoRT74
Valencia, España
Just wondering! Did you check the link I posted?
[Re: NachoRT74]
#2429272
01/05/18 12:33 AM
01/05/18 12:33 AM
NachoRT74
Valencia, España
This they have a Phone number there... if you care to get the one you still need I'm waiting for the next email reply for the BB ones.
