2009 up Ram 1500 5.7 exhaust manifold issues #2403680
11/14/17 08:48 PM
11/14/17 08:48 PM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
Just wondering if anyone has experience with the "breaking" exhaust manifold studs, allowing the manifold to warp and leak. Apparently Mopar had a TSB about changing the studs with a different type material stud . . .however, if the manifold isn't planed flat, then the whole issue will happen again . . .
It is diagnosed as a "ticking" noise when cold, but as the head and manifold heat up, they "seal" up the leak . . . but with enough time and heat/cool cycles, the manifold can warp . . . no recall was ever issued, apparently it is on virtually all 09 and up truckes (happens around the 35-40k mile mark) . . .
Re: 2009 up Ram 1500 5.7 exhaust manifold issues [Re: a12rag] #2403691
11/14/17 09:06 PM
11/14/17 09:06 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That's why I went to shorty headers on both my 5.7 Hemis. Happens on the earlier models also.
Re: 2009 up Ram 1500 5.7 exhaust manifold issues [Re: a12rag] #2403715
11/14/17 09:47 PM
11/14/17 09:47 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Just got mine replaced this summer - warranty work to 100k.
Re: 2009 up Ram 1500 5.7 exhaust manifold issues [Re: 1E2C] #2406203
11/20/17 02:46 AM
11/20/17 02:46 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
We do a lot of them at the shop,not aware of a change in the studs though. Been get them from Dorman they have a manifold kit and a lot cheaper. BTW try getting a ice pick and tap the broken stud around. 50% of the time they are not seized in the hole. Also remove the inter fender liners for access.
Re: 2009 up Ram 1500 5.7 exhaust manifold issues [Re: a12rag] #2406432
11/20/17 05:22 PM
11/20/17 05:22 PM
a12rag Offline OP
a12rag  Offline OP
Cool . . thanks for the tip !
