Page 5 of 5 < 1 2 3 4 5
#2403617 - 11/14/17 03:42 PM Crane Iron Rockers 1.5, 9.130 ball cup Crane Pushrods [Re: moparts]
1KoolBee Offline
Loc: San Diego, CA
Complete set of 1.5 ratio Crane Nodular Iron rockers . These rockers are good used condition. Rocker tips were redone by Rockers Unlimited and adjusters are excellent. Several rockers have some minor scoring in the bore. PM me your email for pix. Could add banana grooves in shafts and run as-is in milder builds, or send off to Dvorak Machine or Rockers Unlimited and have them bushed which would make them last forever. Included are 3 used chrome shafts that show some wear but should be usable with minor polishing. Springs included. Priced accordingly at $200 plus the ride.
Complete set of Crane chromoly ball/cup pushrods. 9.130 overall length (tip to top of cup. These are in excellent shape, with almost no signs of any use. I think they are for 413-440 with adjustable rockers and hydraulic lifters (and EDM solid lifters) but you should measure your setup to be sure. $75 plus the ride.
One brand new left iron crane rocker 1.6, bought as a spare for another set of rockers I just sold. $30 plus the ride.
Thanks Moparts
#2403643 - 11/14/17 04:29 PM BB Rocker Arm Spacer Springs [Re: moparts]
BradH Offline
Loc: Valhalla... eventually
Does anyone need 1 or 2 sets of BB rocker arm springs like the ones that come w/ Crane rockers? I found a couple of sets of 8-each recently while digging up a few spares for someone and figured I'd make 'em available.
$15 per set or $25 for both sets, including shipping in the lower 48.
PM me here. Thanks - Brad
#2403676 - 11/14/17 05:37 PM Firecore dist, MSD coil & MS 8.5mm wires [Re: moparts]
topside Offline
Loc: So Near, Yet So Far
Nearly new (500 miles)for RB: Firecore mech distributor with MSD Blaster2 coil & SuperConductor spark plug wire set. Very nice condition, works perfectly, except 1 plug wire is mismatched due to a header burn.
I changed to a vacuum advance unit & different coil for street driving.
Setup cost $340, but $250 gets it to your door in the US.
PM me here, thanks.
#2403894 - 11/15/17 08:23 AM parts for sale [Re: moparts]
gdmusclecar Offline
Loc: ORANGE PARK,FL
440 six rods and new 0.30 trw six pack pistons $599 set
73-74 440 hp (lh) exhaust manifold $199
72 400-4spd distributer part #3656329 $69
orange park,fl
e-mail: gdmusclecarparts@yahoo.com
shop # 904-272-1803
cell # 904-589-4645
Edited by gdmusclecar (11/15/17 08:24 AM)
#2404184 - 11/15/17 05:35 PM 1978 Thermoquad 9112s and 1973 oem 440 Valve Covers [Re: moparts]
Adam71Charger Offline
Loc: Tacoma, Washington USA
I have a used 78 thermoquad in good condition. Clean and complete. Hasnt been run in years, so a rebuild is in order. I want $50 plus shipping. You can text me at 253 691 4880.
follow the link to see more pictures. Im also selling 2 distributors and 1973 440 valve covers.
20171113_190517 by Richard Bailey, on Flickr
20171113_190616 by Richard Bailey, on Flickr
20171113_190157 by Richard Bailey, on Flickr
20171113_190434 by Richard Bailey, on Flickr
20171113_192843 by Richard Bailey, on Flickr
Edited by Adam71Charger (11/15/17 05:37 PM)
#2404423 - 11/16/17 08:00 AM big block parts for sale [Re: moparts]
gdmusclecar Offline
Loc: ORANGE PARK,FL
440 crossram edelbrock str intake nice $1,999
orange park,fl.
shop # 904-272-1803
cell # 904-589-4645
#2404795 - 11/16/17 11:13 PM 1971 400 Block 230 Cast Thick Main [Re: moparts]
Newbomb_Turk Offline
Loc: Archbald, PA
I have for sale a 1971 400 230 casting thick main block. Casting date 7/71, Std bore, virgin motor. Has 1 broken bolt in water pump mount, not a big deal to fix. Will meet within reason or can pallet & drop off at truck freight shipper. $1200. OBO
Email is the best way to get me
newbombturk1@earthlink.net
Thanks, John
Edited by Newbomb_Turk (11/19/17 02:35 PM)
1971 Demon 440 auto Drag car full tub, Best 10.47 @ 126
#2405382 - 11/18/17 08:42 AM Re: 1971 400 Block 230 Cast Thick Main [Re: Newbomb_Turk]
69 charger man Offline
Loc: NJ
Power steering pump core with pulley. Not really sure what it came off, but should fit a bunch of stuff. 10$ plus shipping. Please pm me. Thanks for the add
#2405654 - 11/18/17 06:17 PM Factory iron intakes [Re: moparts]
gss Offline
Loc: State, country, etc.
Factory cast iron intake manifolds. Good shape, need to be cleaned and painted.
1. 1967 440 HP #2806178, date 2-10-67 $40
2. 1969 383 #2806301 $SOLD
3. 1972 400 #3614046 spread bore, no EGR $10
4. 1976 440 4v #3830949 $10
Prices plus actual shipping from MN 55807
Edited by gss (11/19/17 07:12 PM)
#2405845 - 11/19/17 06:43 AM 3.900" Stroker Crank for B-engine. New. American steel. [Re: moparts]
YYZ Offline
Loc: Toronto (YYZ) Ontario
Brand new Mopar Performance B-engine stroker crank for 361/383/400/426
This is one of the American-made cranks, excellent steel, that was made with a 3.75" stroke, B-engine main journals and an 8-bolt Hemi flange.
I have had the crank offset ground and indexed by a local shop to exactly 3.900" stroke, perfect TDC and 2.200" rod journal sizes for much better rod and bearing choices.
The shop does many cranks for Tim Banning/FHO.
I have almost $2K into the crank with the work, it is ready to drop in.
$800 plus the ride.
inviolet@outlook.com or PM me on the board
#2405897 - 11/19/17 10:31 AM Holley 3310-2 4bbl carburetor. 750 CFM [Re: mopars4life]
streetkit Offline
Loc: Northern CA
Holley 3310-2 4bbl carburetor. 750 CFM Vacuum Secondary Dual Feed Performance Carburetor with a manual choke. This carb is used and it has been sitting on a shelf for a while so it will need to be rebuilt. It is not frozen. Chrome fuel line is included.
$100 shipped to your door anywhere in the USA.
Located in Northern CA.
glolas@comcast.net
1973 Dodge D100
#2406336 - 11/20/17 11:43 AM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
bbtrux Offline
Loc: ohio
carburetors - 4781-2 850 double pumper off of running car - $200.00 OBO ; Holley 4749-2 , correct for 67-70 383 and 440 in non carter applications , needs rebuild - $50.00 OBO ; carter AFB 3615S ,correct for 64-67 413 , needs rebuilt - $50.00 OBO ; thermoquad 9151S , correct for 78 440 truck , needs rebuilt - $50.00 OBO ; 6518SA , industrial (rv) 440 carb , needs rebuilt - $50.00 OBO ; 6518S thermoquad , industrial 440 (rv) , needs rebuilt - $50.00 OBO ; 6488S thermoquad , correct for 74 360 automatic , needs rebuild - $50.00 OBO - 9182S thermoquad , correct for 78 400 auto , needs rebuild , bowl vent and air cleaner stud bent - $25.00 OBO ; Holley 6180-1 , dont know application , needs rebuilt - $50.00 OBO ; Holley 6189 , dont know application , needs rebuilt - $50.00 OBO . Call or text 419-512-1612 , or e-mail rocknwrench@gmail.com. Thank you.
Edited by bbtrux (11/20/17 11:44 AM)
#2406523 - 11/20/17 06:49 PM 1973 440 Pistons and Rods standard bore [Re: moparts]
1971louvergtx Offline
Loc: melbourne, florida
I am rebuilding the engine in my 1973 town and country, and decided on new rods and bigger pistons. I have for sale the old piston and rod assemblies, 8 each. The engine had approximately 115k miles on it. The pistons are standard bore, and cylinders had acceptable numbers for taper and out of roundness. Pistons are flat top, about 8.2 to 1. LY rods with bolt/nuts.
Engine was never apart until I pulled it down.
Not sure what they would be worth to someone.
$150 or offers PLUS actual shipping from 32935. I hate to throw them in the trash, but don't need them any more.
roadrunner69 (at)cfl.rr.com
321-863-372nine
Edited by 1971louvergtx (11/20/17 06:49 PM)
#2406611 - 11/20/17 09:51 PM Re: For Sale - Big Block Engine - 4th Quarter [Re: moparts]
H4E2M6I Offline
Loc: Belvidere,IL N.W. Chicago ...
50+ yr old barn find off of a 383. Rare intake and non original Carter carbs. Don't really know that much about this combo or condition of these carbs but they look their age. Part # on manifold reads 1827899-1 and a code ? above that is J 16 7 Selling this combo at $450 This manifold was not factory installed but was only available as a dealer installed performance option or sold across the dealers parts counter. Serious calls only please. 815-218-1733
Edited by H4E2M6I (11/20/17 10:58 PM)
#2407195 - 11/21/17 11:16 PM 440 6 pk coil bracket [Re: moparts]
GKMOPAR Offline
Loc: Hilliard, Ohio
Have a 440 6pk coil mounting bracket. Never used. $20 plus shipping.
#2408289 - 38 minutes 24 seconds ago Re: 440 6 pk coil bracket [Re: GKMOPAR]
Joesixpack Offline
Loc: APACHE JUNCTION AZ
7 NOS IGNITION CONDENSERS#1881 757 MOPAR,DODGE,PLYMOUTH WITH # ON IT
FITS CAST IRON DISTRIBUTORS, AND 361-383-413-426-440 DUAL POINT DISTRIBUTORS. $85
cowgerwilliam035@gmail.com
Edited by Joesixpack (37 minutes 58 seconds ago)
#2408290 - 35 minutes 19 seconds ago Re: 440 6 pk coil bracket [Re: Joesixpack]
Joesixpack Offline
2 NOS MOPAR IGNITION CONDENSERS CH-108
#2875939 WITH PENTASTAR , WITH # ON IT
FITS DODGE&PLYMOUTH CAST IRON DISTRIBUTORS, AND 383 HP 440 HP,426H DUAL POINT DISTRIBUTORS. $50
24,967 Registered Members
185,435 Topics
Fuel line size question
by GardnerJamesW
11/24/17 01:13 PM
Radiator shroud repair, what works? Glue? Custom mix or ?
by Alaskan_TA
11/24/17 12:31 PM
Hotchkis 19367 torsion bar- A question?
by moparAL
11/24/17 12:20 PM
Need help 05 Town and Country drivability issue
by Dixie
11/24/17 12:05 PM
