What battery and why, new build clean sheet of paper
#2403500
11/14/17 02:05 PM
11/14/17 02:05 PM
Posts: 625 Indianapolis In. usa
Quickrunner
-------------------------------------------------------------------------------- New build, clean sheet of paper. What battery (leaning towards Optima) group size? post configuration? And why
Will be trunk mounted and have master disconnect bracket already welded to cage. build is drag week type car and will have electric water pump, fuel pump, Dominator EFI, fans, AC, etc etc...and will run a 1 wire type alternator.
Looking for a clean, trouble free install and NHRA legal hold down system. Some of these aluminum hold downs I see for sale on line don't look sturdy enough to pass tech.
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: What battery and why, new build clean sheet of paper
[Re: Quickrunner]
#2403520
11/14/17 02:51 PM
11/14/17 02:51 PM
Posts: 7,477 Minnesota
Hemi_Joel
Minnesota
The answer depends on what you are going to do with the car. Street or bracket vs. heads up. If weight matters, lithium is the way to go.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Quickrunner]
#2403794
11/15/17 12:40 AM
11/15/17 12:40 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Optima is easy, replacements are available on the road, there is many different hold down options available, and they work well. I run EFI, Two Electric fans, Electric water pump, two fuel pumps, and all the other street car crap. My Yellow top is 7 years old and has 5 drag weeks and lots of passes on it, it is doing great. I work for a battery company and I put a load test on it every year before I go on drag week and so far so good. I do load up a spare for drag week but have yet to need it.
If you go optima you will want a yellow or blue top. They are the same battery but different layouts and warranty. The yellow has top and side posts and the blue has an automotive post and a 5/16th stud because it is designed for marine use. While the batteries are the same under the cover they carry different warranties, the yellow has a 36 month free and the blue a 24 month.
The downside is of course the weight.
68 Barracuda Formula S 340
[Re: ahy]
#2403834
11/15/17 02:32 AM
11/15/17 02:32 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Carrying around a bunch of unnecessary weight is hard on parts.. I recently switched out my red tops.. to a pair of Antigravity 720's we took the car out for a weekend of racing.. and ended up running just a single battery. That only weighed 3 lb.. these batteries are amazing.. today I picked up a 780 to do some more testing. It weighs approximately 4 lb.. they get a little nervous because I don't have an alternator.. but so far so good
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2403835
11/15/17 02:34 AM
11/15/17 02:34 AM
WHITEDART
bean town ....Ca
this is the temporary home.. it is sitting in the old red top footprint..
[Re: Quickrunner]
#2403846
11/15/17 03:38 AM
11/15/17 03:38 AM
Posts: 43,123 Bend,OR USA
Cab_Burge
For your deal I would buy and use a group 27 RV/Marine battery,(conventional lead acid or AGM ) they can sit for long periods of time unused and still stay charged up
[Re: Triple Threat]
#2403927
11/15/17 12:40 PM
11/15/17 12:40 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Nice find! I was looking at this: https://earthxbatteries.com/shop/etx1200but the low reserve capacity had me concerned for something that will see street use. the Indura unit is almost 2x the capacity for the same price. LiFePO4 is definitely the way to go IMO
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: Quickrunner]
#2403935
11/15/17 01:01 PM
11/15/17 01:01 PM
Posts: 19,360 Las Vegas
Al_Alguire
Las Vegas
Tons of lithium batteries out there. HOWEVER the big issue with them is charging rate and maximum voltage. When they get over charged they tend to combust. The problem with your set up is the alternator. You will note they all have a maximum rate and voltage for charging. If you go this way make sure you alternator does not exceed these numbers. The fires that involve lithium batteries are usually caused by over charging them, either rate or voltage. Having said that just follow manufactures direction and they work very very well. Will crank the engine over effortlessly as well. But don't follow their instructions make sure you have good insurance. I run a single Lithium ion battery in my TS car. Cranks the thing over way better than the two 16V AGM's it reaplced. And weighs 8lbs as it is in a conventional group 24 sized case.
[Re: Quickrunner]
#2403969
11/15/17 02:23 PM
11/15/17 02:23 PM
Al_Alguire
Las Vegas
Mine are 16v by preference. Since I switched to 16V years ago I would never go back. Car cools down so much faster this way. Mine is a Lithium Pro and a Go Lithium
[Re: Quickrunner]
#2404027
11/15/17 04:41 PM
11/15/17 04:41 PM
Quickrunner
Weight is not an issue for me, car will be heavy anyway since its not a gutted bracket car. Not really interested in the Lithium deal. I have had good luck in the past with Optima red tops so may just stick with what I know works. I am intrigued with the yellow top and its better warrantee and the dual top & side post. Holley insists on direct connection to the battery for the EFI main power harness and this way I can dedicate the side terminals for that and run the top posts to standard ground and main push/off disconnect to power rest of the car.
[Re: Quickrunner]
#2404031
11/15/17 04:58 PM
11/15/17 04:58 PM
Posts: 11,708 Portage,michigan
B3422W5
Portage,michigan
Had a bunch of different batteries over the years. Finally sticking with interstates. They have yet to let ne down
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Quickrunner]
#2404037
11/15/17 05:10 PM
11/15/17 05:10 PM
Posts: 2,631 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Optima. Because I was at the track one day and watched a guy crank a SBC that wouldn't start for 30 minutes. Plus, I hear they last forever.
2011 Drag Pak Challenger
[Re: Quickrunner]
#2404048
11/15/17 05:24 PM
11/15/17 05:24 PM
Triple Threat
Renton Washington
Since weight isn't an issue, I'd say just go with the Yellow Top Optima. That is what I have in my Dart.
[Re: Triple Threat]
#2404057
11/15/17 05:34 PM
11/15/17 05:34 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I sure miss the old Sears Platinum batteries. 200.00 on sale with a 5 year free replacement. Matt and I still have one in our race cars
[Re: Quickrunner]
#2404109
11/15/17 06:44 PM
11/15/17 06:44 PM
Bad340fish
Tulsa OK
Go with the yellow over the red, the reds are designed for cranking only. The yellow is better suited for something that does some cycling like running fans and pumps with the engine not running.
