Page 4 of 4 < 1 2 3 4
#2398843 - 11/05/17 11:31 AM Re: 1969 B-Body 18 Spline Hemi 4-Speed Transmission [Re: moparts]
Moparlang Offline
Loc: MD
1969 Hemi 4-Speed For Sale. This trans is out of an A34 Coded 1969 GTX that was totalled in the 1970's, VIN L9G275558, build date of 5-26 according to the fender tag. It was a 440 car that had about 30k miles on it. This was installed in a 1972 Cuda show car back then and was rarely driven. As you can see, it has the later model tailshaft housing on it with the dual shifter mounts on it. This is a good working trans, with little movement in the input bearing, input bearing retainer has some surface rust, but no grooves and needs to be cleaned. Stamping on the VIN area is PP833 9G275558. Asking $1800.00. PM me for more info or pics.
Thanks Moparts!!
https://photos.google.com/album/AF1QipPzLAYei3YukqQLl8ynprIyg6po4NK5HhdbPNQm
The "mailman's son" Bad mailman!!
#2399398 - 11/06/17 12:26 PM 426 hemi transmissions for sale [Re: moparts]
gdmusclecar Offline
Loc: ORANGE PARK,FL
70 426 hemi transmission case part #PK3410671 $1,300
69 426 hemi auto transmission part #PK2892094 apart and missing a few parts $1,500
66 426 hemi auto transmission part #H2538389 apart and missing parts $750
69 b-body 4spd transmission 23 spline $749
orange park,fl
email: gdmusclecarparts@yahoo.com
shop # 904-272-1803
cell # 904-589-4645
Edited by gdmusclecar (11/06/17 12:40 PM)
#2400115 - 11/07/17 04:41 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
mosweethemi Offline
Loc: VA.
Hello I have a 1969 Barracuda or Dart transmission for sale that came in a 383 car. Part number 2892091 needs rebuilt . $1000.00 or best offer e-mail me at mosweethemi@yahoo.com or call 540-337-4310 and on here . thanks Moparts O.B.O
Edited by mosweethemi (11/10/17 06:24 AM)
#2400635 - 11/08/17 03:44 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
CRT Offline
Loc: Cedar Lake IN
10% off all trans parts ( not including torque converters ) or
$100.00 off any CRT "PRO" Series transmission.
Friday 24th & Monday 27th from 10am-6pm Chicago time
call 219-374-0100 or order on line at www.CopeRacingTrans.com
Edited by CRT (11/15/17 11:51 AM)
Cope Racing Transmissions
#2400706 - 11/08/17 06:42 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
junkyardmaxie Offline
Loc: OH
1971 904 stock valve body [ rod doesnt come with it had to use it on man valve body]and steel pan both good condition $40.00 plus shipping
#2400709 - 11/08/17 06:50 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Loc: OH
727 heavy duty trans parts NEW $28.00 shipped
#2400730 - 11/08/17 07:36 PM 383 400 440 Truck - 4X4 - 727 Transmission [Re: moparts]
Mopar_Mike Offline
Loc: Danville, NH
This is a good 1973 (part number on rail *3898856..........400/440.....727..........truck, 4WD, long-heavy duty) Big Block Truck 4X4 727 transmission. Comes with original converter. $150 No shipping unless you arrange it.
fas141@comcast.net
Edited by Mopar_Mike (11/08/17 07:40 PM)
RS23L7 440 4-Speed
RS27L7 440 727
WS23L7 484 Hemi - 727 - Dana 4.10
WS27L7 440 727
#2401598 - 11/10/17 06:51 PM A body 4 speed tailshaft and housing [Re: Mopar_Mike]
Genuinejed Offline
Loc: Spokane,WA
A body four speed output shaft and housing.
Nice shape. $300 shipped.
Genuinejed2@aol.com
Edited by Genuinejed (11/10/17 06:52 PM)
1968 Plymouth road runner 1968 Dodge Coronet 500 64 D200 Good, Fast, Cheap. Pick Two.
#2401603 - 11/10/17 06:59 PM 4 speed case [Re: Genuinejed]
Genuinejed Offline
Loc: Spokane,WA
Had 18 spline guts in it, early small bearing version good shape.
$150 plus shipping
Genuinejed2@aol.com
#2402124 - 11/11/17 05:48 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Scotts72Rallye Offline
Loc: Third Stone from the Sun
Lokar KD-2727HT
Chrysler TF-727 Stainless Steel Kickdown Cable Kit, Brushed Finish, Aluminum Fittings and Ferrule. Need more info just see the links below. Summit and Jegs are both asking $76, I'm only asking $60 with free shipping to the lower 48 states. PM me here if interested. Thanks!
Info links:
http://www.jegs.com/i/Lokar/625/KD-2727HT/10002/-1
https://www.summitracing.com/parts/lok-kd-2727ht
Edited by Scotts72Rallye (11/11/17 05:58 PM)
1972 Dodge Challenger Rallye
UNDER CONSTRUCTION
#2402152 - 11/11/17 06:21 PM Re: New 5.13 Richmond Gears, 8 3/4, 742 case [Re: moparts]
PHYSIXX Offline
Loc: Edison, New Jersey
I have for sale a new set of Richmond Gear 5.13 gears for the 8 ¾ rear with the 742 housing. These gears have never been used and are still in the original box.
https://www.summitracing.com/parts/rmg-6901451
I would like to get $170 for the set shipped to any US location.
Edison, NJ
rider1454@aol.com
#2402486 - 11/12/17 10:59 AM Re: New 5.13 Richmond Gears, 8 3/4, 742 case [Re: PHYSIXX]
Joesixpack Offline
Loc: APACHE JUNCTION AZ
NORS USA MADE Neutral safety switch,1965-1966-1967-1968 727, $50 plus 8 priority mail
cowgerwilliam035@gmail.com
#2402660 - 11/12/17 04:04 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Ellies Dart Offline
Loc: South Bend, Indiana
Torque converter out 77 Ram Charger ,had 360ci cast crank motor.it has about 750 miles on it when truck was rolled over, $100 plus shipping from south bend in 46628. 574-274-8214 or elliesdart@comcast.net. popcorn
#2402763 - 11/12/17 07:41 PM Re: Mopar Transmission For Sale - 4th Quarter [Re: moparts]
Quicksilver440 Offline
Loc: Central Valley, CA.
OEM 130 tooth internal/neutral balance 340/440 6 bolt flywheel $135
Part No. 05-029 LUK Clutch/pressure plate/Throw-out bearing Kit Repset Brand new...installed and removed when my son realized his bell housing required a different flywheel and clutch for the starter to engage. $80
Edited by Quicksilver440 (11/12/17 07:51 PM)
First time out, best ET was 11.67 at 116.56 mph
...Rob
#2403176 - 11/13/17 04:38 PM Slant 6 833 Alum Bellhousing [Re: Quicksilver440]
jcc Offline
Loc: Trumussia
Used, will fit other Trans, has had clutch Z bar bosses removed for Hyd clutch package application, they are not likely reinstallable. uses the larger pilot (OD?),may need to acquire reducer bushing in your application, all threaded holes have been chased, as is, as pictured, ships from SW Fla, $100 + shipping/packing, payment within 7 days, PM
Edited by jcc (11/14/17 09:24 AM)
#2403892 - 11/15/17 08:11 AM parts for sale [Re: moparts]
gdmusclecar Offline
Loc: ORANGE PARK,FL
70 t/a challenger,aar cuda 340 six pack automatic transmission part #3410769.This trans is complete $2,000
8-3/4 3.23 suregrip chunk 489 case $895
8-3/4 3.91 ring and pinion $150
e-body 4spd transmission tailhousing $275
orange park,fl.
e-mail: gdmusclecarparts@yahoo.com
shop # 904-272-1803
cell # 904-589-4645
#2404236 - 11/15/17 07:23 PM Two 833 A Body transmissions for sale ****sold**** [Re: moparts]
GKMOPAR Offline
Loc: Hilliard, Ohio
I have 2 - 833 4 spd transmissions for sale. One is a 69 VIN LM23P9B1XXX34 (can't quite read the middle 3 #s) and the other is a 70 VIN 0R220932. I purchased these a couple of years ago for my Demon but have found another that is a better match. I have not tried them. They appear to be in good shape. I can turn by hand and shift into different gears. Come with shift levers and shifter mounting pads. Price is $400 each. Prefer local pickup. Thanks
Gerry
******sold******
Edited by GKMOPAR (11/18/17 07:59 AM)
24,967 Registered Members
185,435 Topics
Spy Spots Released of New Re-Designed 2018 Jeep Wrangler
by Rustymuscle
11/24/17 01:28 PM
Fuel line size question
by GardnerJamesW
11/24/17 01:13 PM
Radiator shroud repair, what works? Glue? Custom mix or ?
by Alaskan_TA
11/24/17 12:31 PM
Hotchkis 19367 torsion bar- A question?
by moparAL
11/24/17 12:20 PM
