Re: are oversize hyd lifters available? 360 SB
[Re: BSB67]
#2401037
11/09/17 04:27 PM
11/09/17 04:27 PM
RapidRobert
From the "partsvoice" search: #1 3549990 (.001). #2 3004644. #3 3614321. #4 4049338. #5 3549991 (.008"). I ain't sure what the descrip of 2,3 & 4 are. CJ motorsports has (14) of #1 and none of #5. "collectors" has (11) of #1 (4) of #2 (9) of #3 (6) of #4 (0) of #5. Brads NOS parts west columbia south carolina Chrysler has 1 of #1. none of #2. (9) of #3. none of #4. none of #5. Silkis (sp) auto parts in jacksonville florida has none of #1 #2 #5 and (8) of #3 and (9) of #4. I am waiting to hear back from Paul at Hylift johnson. lambert auto sales in claremont new hampshire has none of #1 #2 #3 #5 and (14) of #4 EDIT So CJ has (14) .001" and "collectors" has (11) .001" and Brads has (1) .001" & I will post what Hylift Johnson has to say when he calls. No (.008") as of yet
[Re: dogdays]
#2401086
11/09/17 06:31 PM
11/09/17 06:31 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The phone number listed above is for Rurallife magazine, published by the same company that gave us Farm Journal and The Dakota Farmer. How could they be a lifter manufacturer? Current number for Hylift Johnson is: Sales and Service: (800) 441-1400 ext 500
[Re: Paul_Fancsali]
#2401091
11/09/17 06:38 PM
11/09/17 06:38 PM
RapidRobert
So i hunted for a oil dip[stick heater worked like a charm Another dynamite idea, bro you have outdid yourself today!
[Re: RapidRobert]
#2401205
11/10/17 12:36 AM
11/10/17 12:36 AM
Posts: 6,089 Valencia, España
NachoRT74
Valencia, España
Damn! Now I'm confused if I have hilift johnson or Johnson lifters... btw johnson lifters doesn't have them ( just got the reply to my email request )
[Re: Dave Hall]
#2401208
11/10/17 12:43 AM
11/10/17 12:43 AM
Posts: 4,309 Prospect, PA
BSB67
Prospect, PA
How is .016 equal to .025? I am not that familiar with small blocks and really never liked the stock lifter, pushrod geometry. I would imagine with all that crazy side load that the lifter bores will wear out on these? I've never seen a lifter that felt "loose" in its bore but again I have BB's. I would imagine that as soon as the lifters started getting loose in their bores that they could really start wobbling the hole out pretty substantially. If they do wear out enough to cause a pressure loss, wouldn't it be a good idea to get them bushed? The bushing will provide the correct pressure even if after time it wears out of spec. .25" dia. Hole, not .025 clearance. Do you really want me to show the math? I will if you like. Maybe I made a mistake. I don't get the sense this is a high end build. Measuring stuff could be an option too. Silly right
[Re: RapidRobert]
#2401390
11/10/17 02:10 PM
11/10/17 02:10 PM
Posts: 14,479 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The difference in area between .904 and .905, 16 times, is .02272sq/in. This is equal to about one .170" diameter hole(.02269sq/in). That's a pretty big leak. I don't get the sense this is a high end build. Measuring stuff could be an option too. Silly right Measure??? What a novel idea!!
[Re: RapidRobert]
#2401411
11/10/17 03:11 PM
11/10/17 03:11 PM
NachoRT74
Valencia, España
I just got off the ph with Hylift Johnson & they have the .008" for $300 to my door WHAAAAAT ? ( BTW, just confirmed the ones on my block are HLJ lifters ) Central Jersey motorsports has .001" for $155 to my door HLJ brand ? or which brand ?
[Re: NachoRT74]
#2401486
11/10/17 05:35 PM
11/10/17 05:35 PM
John_Kunkel
Rio Linda, CA
Damn! Now I'm confused if I have hilift johnson or Johnson lifters... btw johnson lifters doesn't have them ( just got the reply to my email request ) Johnson and Hylift Johnson are two different companies.
[Re: RapidRobert]
#2401495
11/10/17 06:01 PM
11/10/17 06:01 PM
NachoRT74
Valencia, España
mopars4ever
good
John_Kunkel
yes I know, just was confused which ones I had... and remembered later they are HLJ ones ( the ones from toplineauto )
RapidRobert
got the reply from Topline crew and you are right on the price... damn that's expensive!!!
