Re: are oversize hyd lifters available? 360 SB
[Re: Porter67]
#2414404
12/06/17 09:49 PM
12/06/17 09:49 PM
RapidRobert
Thanks bro, I will break em in & see what my oil psi is (fingers crossed/prayers said).
[Re: lewtot184]
#2414912
12/07/17 08:48 PM
12/07/17 08:48 PM
dogdays
I don't know how easy it'd be to mask the internals of the hydraulic lifter but the concept was only to increase the lifter diameter by a thousandth or two. I did not think plating the inside of the lifter bore was practical as the block is big and heavy, plus there are many more surfaces that'd need to be masked. The lifter body itself should be more do-able.
There is another factor which is cost. If the cost to plate 16 lifters is too high, then it becomes more practical to sleeve the lifter bores.
Reportedly the electroless nickel coating is very hard. This may provide an advantage to the lifter face.
It is only an idea that could be pursued by an interested party.
R.
[Re: Porter67]
#2415115
12/08/17 09:58 AM
12/08/17 09:58 AM
RapidRobert
What I am gonna do is replace the one lifter that is missing the very thin round plate with the several holes in it that is under the top lifter pushrod cup as Dog convinced me that it is bleeding off pressure & continue the breakin & if the psi is still wacked (& I think it will be as in addition to the fubared lifter, the bores are way too loose) I am gonna go ahead & drop in the .001's that I now have in my possession (15 of em), (1) is being searched for & rebreakin & see if THAT! takes care of it. & if not then I am gonna pull the eng & go with another one. Psi is oscillating in a certain range (I forget the # but it is low) which has to be the lifters then after several minutes it drops to near zero (still oscillating 10 psi or so, so I shut it down. After 5 head gasket changes (which finally go solved!) & hopefully the .001's will solve/finish this out. What happened here is outside issues got to me/affected my mechanical judgement (which ain't happened in decades) causing gross errors. Guys I really appreciate the help & support on this one as it was a toughie ('bout made me wanna throw in the towel) & definitely did test me. I will post if the single lifter or the .001's takes care of this. RR & Yes all pipe plugs are in place.
[Re: RapidRobert]
#2415124
12/08/17 10:30 AM
12/08/17 10:30 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
of course the coat well worths a try! I was overthinking stuff if the wear is bigger and not symetric.
[Re: RapidRobert]
#2415629
12/09/17 07:59 AM
12/09/17 07:59 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
I keep on hearing people talk about honing the lifter bores. What about reaming them? I would think a properly sized ream would result in a truer bore than a honing would. I understand that a ream might be slightly pricy, but if you have several blocks to do it might be a better answer in the long run. If you can find some .008 O/S lifters - ream to .006-.007 and final hone to finish size.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: RapidRobert]
#2416070
12/10/17 04:11 AM
12/10/17 04:11 AM
Porter67
Here are some .030 oversize lifters!!! Spooky looking mugs here!
[Re: RapidRobert]
#2416683
12/11/17 10:57 AM
12/11/17 10:57 AM
NachoRT74
Valencia, España
If I can get .008 I preffer... still need to get measured the bores and the machine shop hasn't being able to get my block due the large ammount of orders... we are waiting to the machine shop they are able to get mine dropped to the shop. Mostly sure will be by january
[Re: Porter67]
#2421112
12/19/17 08:47 PM
12/19/17 08:47 PM
RapidRobert
rather than swap the one that is missing the thin plate with a new std one like I was gonna do, I just went ahead & pulled the intake & I am going to mike the bores & likely just drop in the .001 lifters (I got 15 of em) & rebreakit in & see what the psi does this time.
[Re: NachoRT74]
#2421376
12/20/17 11:44 AM
12/20/17 11:44 AM
RapidRobert
Nacho, On the .001's from the partsvoice search: brads NOS parts no longer has one. I bought all of central jersey motorsports ones. "collectors" does not have any (more). Benoy mtrs (Tom @ 815/308/5100) has some (less than 16, 6 iirc) & they quoted me $26.15 to get ONE to my door. On the .008's jasperbucks1522@gmail.com has em for $300 #22011-08, Dave at ext 611 if a person ends up calling there. I'm hopeing slowing down 15 of my leaks will resolve this, I gotta get over there & make some progress.
[Re: RapidRobert]
#2421380
12/20/17 11:58 AM
12/20/17 11:58 AM
NachoRT74
Valencia, España
I already got the quote from toplineauto ( HiLift Johnsons ) and is slightly better from the seller who attended me. But still hoping a better price option from Australia ? LOL.
But I'm still having the doubt if get the 2011s or the 976s. Wondering why the 976s didn't worked on mine ( 400 )
[Re: NachoRT74]
#2421386
12/20/17 12:10 PM
12/20/17 12:10 PM
RapidRobert
Alright, I just PM'd him again (on the .008's)
[Re: RapidRobert]
#2421436
12/20/17 02:15 PM
12/20/17 02:15 PM
NachoRT74
Valencia, España
I already did... without sucess.
[Re: RapidRobert]
#2421666
12/20/17 11:46 PM
12/20/17 11:46 PM
NachoRT74
Valencia, España
well... we don't know if could be better try to get them shipped to USA then 16 of them forwarded from there to Venezuela ( I have a forward courier there )... or backwards. I guess is better try to get the price of the set LOL, then the shipping method
