#2400886 - 11/09/17 06:30 AM 1970 B-body hoods
hemi68charger Offline
Loc: Houston, Tx
Operation Superbird hood repair;
Looking for a 70 B-hood, more specifically a 70 Coronet.
Blue hood is the '70 Coronet hood I have now, the cleaned/yellow is the original Superbird hood
Question, any B-body underhood support structure would work? Or not? Mike G?
Edited by hemi68charger (11/09/17 06:31 AM)
Troy
Houston Mopar Connection Club
#2401182 - 11/09/17 08:13 PM Re: 1970 B-body hoods [Re: hemi68charger]
NANKET Offline
Loc: northwest USA
They front underside part of the superbird hood is unique.
#2401219 - 11/09/17 10:09 PM Re: 1970 B-body hoods [Re: NANKET]
Loc: Houston, Tx
Yes, I agree.... I was looking to transfer the underside frame work on my hood out since it has corrosion. The top skin is pretty nice.... I was curious of the underside frame work of a '70 Coronet was similar, if not the same, as that of say, a '70 Belvedere or Charger....
But I did find today a real nice '70 Coronet hood for $250.... So, that is good...
Troy
#2401223 - 11/09/17 10:20 PM Re: 1970 B-body hoods [Re: hemi68charger]
NANKET Offline
Loc: northwest USA
I know folks have used a Superbee bulge hood and put the superbird front on it to use it on the superbirds. I think the 70 coronet hood is the one to use so it good you found one. Can you compare it to your bird hood underside shapes & contours?
I don't know the difference in the underside on 70 Dodge vs Plymouth hood.
#2401241 - 11/09/17 10:49 PM Re: 1970 B-body hoods [Re: hemi68charger]
NANKET Offline
Loc: northwest USA
I have a flat 1970 Plymouth hood. Do you want pictures of the underside?
#2401259 - 11/10/17 12:09 AM Re: 1970 B-body hoods [Re: NANKET]
6bblgt Offline
Loc: Las Vegas, NV
there's a thread on dodge-charger where somebody shows the details of what gets modified top & bottom from a Coronet hood to create a Superbird hood
you need flat Coronet hood, upper panel Superbird hood extension & underside Superbird filler panel
nothing Charger or Belvedere will help sawzall
- Dan
#2401712 - 11/10/17 10:20 PM Re: 1970 B-body hoods [Re: 6bblgt]
Loc: Houston, Tx
I got a 70 Coronet hood today....
The inner structure is what I was looking for comparisons... But, the '70 Coronet inner structure is what is used with it trimmed in the leading edge to facilitate the installation of the extension.... So, looks like it is a mute point thread now... So, we'll take the outer skin and both the upper and lower extension portions and replace the inner structure from the good Coronet hood I just got and mate it to the Superbird panels....
Troy
25,487 Registered Members
193,023 Topics
1974 Satellite Strut Rid Bushings
by 70Coronet500Vert
09/21/18 07:31 PM
A/C Brackets
by ++MAX WEDGE++
09/21/18 07:12 PM
Power windows
by challenger6pack
09/21/18 06:20 PM
Home Portable Generator / Natural gas
by VCODE
09/21/18 05:37 PM
