#2401689 - 11/10/17 09:34 PM 5.7 block (pre-VVT) engine mounting vs Eagle/Apache
moparmitch Offline
Loc: Michigan
Hello All,
I've obtained an early (pre-VVT) 5.7 block to use as a mockup to fab solid engine mounts and a mid-plate. My intentions are to use a newer Eagle or Apache based engine for the final install, along with a 727 trans.
Anyone know if the external dimensions/relationships for the rear face of block to the engine block mounting pads on the sides of the older/newer blocks are the same?
My limited research indicates these relationships are the same for all G3 blocks, but I would like to hear from those who have experience.
Thanks!
#2401696 - 11/10/17 09:54 PM Re: 5.7 block (pre-VVT) engine mounting vs Eagle/Apache [Re: moparmitch]
HotRodDave Offline
Loc: Kalispell Mt.
thats all the same
68 cuda 360 notchback SOLD
1996 Ram 2500 5.9 eddy intake EQ heads, mild cam upgrade great tow rig!
25,149 Registered Members
186,780 Topics
Nudder 64 Dodge 2-door Post
by bigdad
02/23/18 11:34 AM
Remember when Mother Mopar sold crate motors & short blks
by bigdad
02/23/18 11:29 AM
How cheap are late model Challengers ?
by bigdad
02/23/18 11:25 AM
Sad face Challenger in Arizona
by bigdad
02/23/18 11:13 AM
