#2401689 - 11/10/17 09:34 PM 5.7 block (pre-VVT) engine mounting vs Eagle/Apache
moparmitch Offline
Loc: MI, USA
Hello All,
I've obtained an early (pre-VVT) 5.7 block to use as a mockup to fab solid engine mounts and a mid-plate. My intentions are to use a newer Eagle or Apache based engine for the final install, along with a 727 trans.
Anyone know if the external dimensions/relationships for the rear face of block to the engine block mounting pads on the sides of the older/newer blocks are the same?
My limited research indicates these relationships are the same for all G3 blocks, but I would like to hear from those who have experience.
Thanks!
#2401696 - 11/10/17 09:54 PM Re: 5.7 block (pre-VVT) engine mounting vs Eagle/Apache [Re: moparmitch]
HotRodDave Offline
Loc: Kalispell Mt.
thats all the same
25,632 Registered Members
195,661 Topics
Great Old Tom Hoover Quote:
by Sunroofcuda
9 minutes 26 seconds ago
1990 Dodge D150 - $3500 Abingdon MD
by N717BH
Yesterday at 09:15 PM
core support to k member brace what size bolts 69 b body
by moparpro
Yesterday at 08:31 PM
EFI- old MoPar- where to get "true power"? Start/run
by CrAzYMoPaRGuY
Yesterday at 07:50 PM
