5.7 block (pre-VVT) engine mounting vs Eagle/Apache #2401689
11/11/17 12:34 AM
11/11/17 12:34 AM
MI, USA
moparmitch Offline OP
MI, USA
Hello All,
I've obtained an early (pre-VVT) 5.7 block to use as a mockup to fab solid engine mounts and a mid-plate. My intentions are to use a newer Eagle or Apache based engine for the final install, along with a 727 trans.
Anyone know if the external dimensions/relationships for the rear face of block to the engine block mounting pads on the sides of the older/newer blocks are the same?
My limited research indicates these relationships are the same for all G3 blocks, but I would like to hear from those who have experience.
Thanks!
Re: 5.7 block (pre-VVT) engine mounting vs Eagle/Apache [Re: moparmitch] #2401696
11/11/17 12:54 AM
11/11/17 12:54 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
thats all the same
