#2401547 - 11/10/17 05:02 PM 511 project falls short update
mopar dave Offline
Loc: flint michigan
Temps are dropping fast this year here, but ran the car a couple times in 40* temps. Creeping up on the dominator tune. Richened the t slot and leaned the pvcr and added timing. Made it very happy. Playing with air bleeds now as i still have a lean issue on the pri at rpm. Im thinking adding jet to pri and reducing secondary a couple. Just need another nice day.
#2401568 - 11/10/17 05:38 PM Re: 511 project falls short update [Re: mopar dave]
Chargerfan68 Offline
Loc: New York, USA
Most just slap on a dominator and mess with jetting and call it done, suffering with miserable part throttle driveabilitu and fouled plugs. Its amazing how crisp and clean a 1050 can run on a street car once you dial in the right settings inside the carb as well as bleeds. My 1050 actually runs cleaner than my 950 hp because i spent more time dialing it in. I dont think ill ever go back.
#2401575 - 11/10/17 05:57 PM Re: 511 project falls short update [Re: mopar dave]
Loc: Bend,OR USA
Don't be afraid to run it at or above 14.8 AFR on pump gas at light part throttle cruise from 1500 to 2800 RPM up scope
Edited by Cab_Burge (11/10/17 05:58 PM)
#2401675 - 11/10/17 08:59 PM Re: 511 project falls short update [Re: Chargerfan68]
mopar dave Offline
Loc: flint michigan
Absolutely. I believe all carbs come with the t slot open. On a Dominator it needs to have a jet in it if ya want good clean drivability. I now have a .056 jet in mine. Works great. Dom showed me that one.
25,156 Registered Members
186,881 Topics
68 Dart Steel Dash Removal
by 68rrunner
02/25/18 10:31 PM
Big-block timing backing up
by 70Drop
02/25/18 09:25 PM
New oem wiring. With aftermarket stereo /amp ...
by toplescuda
02/25/18 09:14 PM
John Force another Crash
by Sammy
02/25/18 08:50 PM
