Car steering wheel adapter VS. truck steering wheel adapter? #2401153
11/09/17 10:03 PM
11/09/17 10:03 PM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
I was looking at steering wheels from Classic Industries and they have one I like that's listed for Cuda, Dart, Valiant, Duster etc. My question is the truck steering column not able to accept one of these adapters and steering wheel? Does it require a different adapter? I figured an automatic column with non-floor shifter would be the same dimensions where the adapter and wheel bolt on. Anyone know for sure?
Re: Car steering wheel adapter VS. truck steering wheel adapter? [Re: GOT6PAK] #2401589
11/10/17 09:32 PM
11/10/17 09:32 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I think they just mention the most popular applications.
As I mentioned in the general section.
I have a Grant type wheel that I took out of a '69 Dart in my 76 D-200.
I have mechanical Aptitude.
I can screw up anything.
Re: Car steering wheel adapter VS. truck steering wheel adapter? [Re: GOT6PAK] #2401661
11/10/17 11:42 PM
11/10/17 11:42 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
What year truck?
I had a '77 wheel from a B-body on the '76 Club Cab I used to own. It fit no problem.
As mentioned, I think they just list the more popular models.
Now, if your truck has tilt wheel, that is a different story.
For reference, this is the wheel I switched to:
John
Re: Car steering wheel adapter VS. truck steering wheel adapter? [Re: GOT6PAK] #2401861
11/11/17 12:57 PM
11/11/17 12:57 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I installed a Grant "Tuff wheel" from Summit on my 68 D100 & it was super simple to put on. IFIRC, as it was last summer when I did it, it didn't need any adapter, but only the turn signal actuator piece that came with the wheel. The 3 holes & screws with the Tuff wheel lined up perfectly with the holes in the column. Took me 15 minutes to install. Only issue I have with it is the smaller diameter obscures a lot of the speedo display, but that's no big deal.
Re: Car steering wheel adapter VS. truck steering wheel adapter? [Re: GOT6PAK] #2402238
11/11/17 11:17 PM
11/11/17 11:17 PM
Dysart,Pa.
K
kork340 Offline
kork340  Offline
K
Dysart,Pa.
4x4 trucks take a different adaptor 2wd trucks use same as a car. If I remember right 4x4 has keyway type spline cars/2wd trucks have no keyway(or vice versa). I remember needing a different adaptor when I put Tuff wheel in my 77 w150, car adaptor I had on shelf wouldn't fit.
Re: Car steering wheel adapter VS. truck steering wheel adapter? [Re: kork340] #2402315
11/12/17 01:22 AM
11/12/17 01:22 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I believe it may have been vice-versa, as the older 4x4's had limited, very limited ways of correcting steering wheel alignment, other than moving the wheel a couple of teeth etc.
Re: Car steering wheel adapter VS. truck steering wheel adapter? [Re: GOT6PAK] #2405815
11/19/17 04:44 AM
11/19/17 04:44 AM
Southern California
GOT6PAK Offline OP
GOT6PAK  Offline OP
Southern California
My truck is a 75' D100 2WD non-tilt column. It does have a keyway. I have a 77' D100 2WD parts truck and that non-tilt column does NOT have a keyway. I don't think I'll have a problem with the adapter because even though the adapter does not have a key way, it will still slide on either column. I think the only time I would have a problem is trying to put a steering wheel with a keyway on a column without a key way. If that makes sense. I found a site called Flashpower that has all the adapters we need. Here's the link...
http://www.flashpowerparts.com/80-dodge-plymouth?p=2
Re: Car steering wheel adapter VS. truck steering wheel adapter? [Re: GOT6PAK] #2405848
11/19/17 10:16 AM
11/19/17 10:16 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
I used the Tuff Wheel look-alike and adapter from my '85 W150 on my sons '71 Charger with no problem. shruggy
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Car steering wheel adapter VS. truck steering wheel adapter? [Re: GOT6PAK] #2405870
11/19/17 11:53 AM
11/19/17 11:53 AM
E
earlymopar Offline
earlymopar  Offline
E
One of the details that seems to be missing on many of the aftermarket adapters (at least for mid-60's trucks) is the pin that cancels the turn signal. Have any of you had this experience?
- EM
Re: Car steering wheel adapter VS. truck steering wheel adapter? [Re: GOT6PAK] #2439486
01/23/18 12:37 PM
01/23/18 12:37 PM
dirkpitt007 Offline
dirkpitt007  Offline
I have a '78 Dodge D150 and the available tuff wheel car adapter with the keyway and while it "works" it does not slide down far enough on the steering shaft. The adapter probably needs to move another 1/4" or so. The problem is the spine in the adapter is bottoming out on the ridge of the shaft. The turn signal pin barely extends far enough and the horn pin does not engage with the ring on the adpater.
I believe the shaft is original but has anyone else seen this?
'70 Cuda 440 six-pack
'71 Cuda convertible
'78 Warlock
