Page 2 of 3 1 2 3
Re: Why do my brakes keep un-adjusting? [Re: mickm] #2402069
11/11/17 07:32 PM
11/11/17 07:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By mickm
Originally Posted By John_Kunkel
You are aware that the self-adjusters only work when the brakes are firmly applied when backing up?
Lots of folks shift to Drive after backing up and seldom/never use the brakes.
Yes, that's why I pried the rear shoe away from the top mount. And as mentioned, it worked as expected.
Yeah, but is the driver actually using the brakes to stop when backing up?
Re: Why do my brakes keep un-adjusting? [Re: mickm] #2402073
11/11/17 07:39 PM
11/11/17 07:39 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Might be hunting up the wrong tree.
If the right brake seems to grab hard, then maybe the left brake isn't grabbing at all. Why? Initial adjustment plays a role, but not to extent described.
20-30 miles is not normally far enough to have made a difference in the shoe lining thickness. Normally - if you're coming down Mt Washington at a clip, wear will be higher. :lol:
If the shoes aren't grabbing, then the self-adjusters won't move.
On the '69 up adjusters, adjusters are actuated in reverse as the secondary shoes grab .
Based on what's posted so far, I'd see if the left wheel cylinder can be bled and if the wheel cyl pistons both move free.
Also, review Chrysler's drum brake advice to techs
http://www.imperialclub.org/Repair/Lit/Master/204/Page01.htm
and '69
http://www.imperialclub.org/Repair/Lit/Master/260/Cover.htm
Re: Why do my brakes keep un-adjusting? [Re: mickm] #2402159
11/11/17 09:40 PM
11/11/17 09:40 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Are the primary and secondary shoes in the correct positions? Not sure if it would cause the issue but I thought I would ask.
Re: Why do my brakes keep un-adjusting? [Re: minivan] #2412931
12/04/17 02:44 AM
12/04/17 02:44 AM
California
mickm Offline OP
mickm  Offline OP
California
So if anyone has noticed, I kind of got sidetracked from the brake issue because I broke the perch that the motor mount sits on clean off of the k frame.
So as I'm taking the whole front end apart to drop the k frame, I did get a chance to take a picture of the brakes. All look good to me, but the first picture is the drivers side, the one that keeps un adjusting.
The passenger side, the one that keeps in adjustment.
Re: Why do my brakes keep un-adjusting? [Re: mickm] #2412934
12/04/17 02:58 AM
12/04/17 02:58 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
is the drivers side adjuster left hand thread?,if not thats your problem
my ladder of success is missing some rungs
Re: Why do my brakes keep un-adjusting? [Re: rhad] #2412959
12/04/17 06:05 AM
12/04/17 06:05 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Yes it's left hand thread, you can see that in the picture. And yes I checked when I saw the picture.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Why do my brakes keep un-adjusting? [Re: mickm] #2412961
12/04/17 06:48 AM
12/04/17 06:48 AM
A727Tflite Online content
A727Tflite  Online Content
Why are the backing plate bolts loose in your first picture?
Re: Why do my brakes keep un-adjusting? [Re: A727Tflite] #2412962
12/04/17 06:49 AM
12/04/17 06:49 AM
amxautox Offline
amxautox  Offline
because he just said in reply number #2412931 at 8:44pm;
Tom
author unknown
Re: Why do my brakes keep un-adjusting? [Re: amxautox] #2412986
12/04/17 11:01 AM
12/04/17 11:01 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
No need to remove those bolts though
Don't be the exception.
Re: Why do my brakes keep un-adjusting? [Re: mickm] #2413022
12/04/17 12:52 PM
12/04/17 12:52 PM
Yep- that threw me - I read his post but no reason to take the backing plates loose -
Re: Why do my brakes keep un-adjusting? [Re: A727Tflite] #2413032
12/04/17 01:07 PM
12/04/17 01:07 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Ive done it that way several times over the years.
Much easier to do it this way than break the ball joint loose. ( aka no pitchfork tool or BFH required to break the ball joint loose. )
This way the lower ball joint and associated suspension components come out the with the K frame / lower control arms / tie rod ends intact.
Re: Why do my brakes keep un-adjusting? [Re: gtx6970] #2413083
12/04/17 03:00 PM
12/04/17 03:00 PM
amxautox Offline
amxautox  Offline
And he doesn't have to break lose the brake lines and have to bleed the brakes. Different ways to get the job done.
Tom
author unknown
Re: Why do my brakes keep un-adjusting? [Re: mickm] #2413092
12/04/17 03:27 PM
12/04/17 03:27 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
First pic looks like you have the shoes mixed up.. Isnt the longer shoe supposed to go on the back??
Re: Why do my brakes keep un-adjusting? [Re: floridian] #2413130
12/04/17 04:25 PM
12/04/17 04:25 PM
California
mickm Offline OP
mickm  Offline OP
California
I'll double check, but I think the shoes are on correctly.
Re: Why do my brakes keep un-adjusting? [Re: gtx6970] #2413131
12/04/17 04:25 PM
12/04/17 04:25 PM
California
mickm Offline OP
mickm  Offline OP
California
Yes, that was the plan...
Re: Why do my brakes keep un-adjusting? [Re: amxautox] #2413136
12/04/17 04:32 PM
12/04/17 04:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Is there enough slack in the brake hose to slide the drum backing plate off the spindle?
Re: Why do my brakes keep un-adjusting? [Re: Supercuda] #2413141
12/04/17 04:39 PM
12/04/17 04:39 PM
amxautox Offline
amxautox  Offline
Might be. If he lifts the arms and spindle up all the way, then it's very possible.
Tom
author unknown
Re: Why do my brakes keep un-adjusting? [Re: mickm] #2413168
12/04/17 05:57 PM
12/04/17 05:57 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Leave the upper control arm, spindle, and backing plate in the car, no need to remove it.
Take the k frame with lower control arms, lower ball joints and all the steering linkage with it, great plan.
You don't need to bleed brakes, align the front end, bust ball joints and rip the boots.
Re: Why do my brakes keep un-adjusting? [Re: NANKET] #2414059
12/06/17 04:29 AM
12/06/17 04:29 AM
California
mickm Offline OP
mickm  Offline OP
California
So this thread seems to have gone a little off track with the k frame removal. what about the brakes? anyone see anything in the pictures, or have any other ideas?
Re: Why do my brakes keep un-adjusting? [Re: mickm] #2414271
12/06/17 04:41 PM
12/06/17 04:41 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Yes, back the brake problem...
when I hit the brakes it pulls sharply to the right. Adjust it out and everything is ok.
What could be causing this?
It is super frustrating for such a simple set up to go wrong, isn't it? You are sure the driver's shoes aren't wearing down prematurely, right? Does the car pull left when shoes are adjusted manually?
Otherwise the car pulling to the side when the shoes wear down for lack of adjustment, could be hydraulic pressure isn't split equally... but you'd have pulling to the left after adjustment..
.. so, OK my gut agrees the problem is in the adjuster system.
(to explain - I had a persistent "unequal braking" problem at my rear brakes a few years ago - the adjuster setup looked dead perfect, so I kept thinking it was hydraulic pressure sending unequal brake force to the rears. End of story was I found a very small discrepancy in the actuator arm's position that didn't let it engage the star wheel properly - it was the cable's eye loop at the TOP of the brake drum resulted in a shorter cable length. Problem solved).
Going back to something very basic: I'd remove the rear brake drums which are working FINE (are they wearing equally?) and compare the fronts to the rears.... compare orientation of brake shoes, star wheel, cables, springs, everything.. my gut tells me something very minor isn't right and you have to find it by careful observation of something that DOES WORK right..
Do you have any Mopar buddies with '70 B-body? My '67 and '65 are just a bit different than yours.
Cheers,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Page 2 of 3 1 2 3
