#2401315 - 11/10/17 08:01 AM 1976 Road runner
dynamite Offline
Loc: NEW JERSEY
On a 1976 Volare .Road Runner edition, with 360 and t- flight,, what trans 904 or A- 727.. and what rear .. 8. 1/4 ???Thanks for any help ....
#2401330 - 11/10/17 08:54 AM Re: 1976 Road runner [Re: dynamite]
Loc: Lincoln Nebraska
by the dist, look down along the top sloped bellhousing of the trans & if there is a circular "bump" all the way around the trans case down where the angle starts to turn back horizontle then it is a 904 or look at the pan & if it is a square with a corner cutout then it is a 904 (727 has a dogleg). On the rear, count the bolts on the center section & are they in front or rear. 7&1/4 has a bolt on rear cover with 9 or 10 bolts & it (the cover) looks like a mini Dana. iirc the 8&1/4 is an oval shaped bolt on.
#2401362 - 11/10/17 10:00 AM Re: 1976 Road runner [Re: RapidRobert]
dynamite Offline
Loc: NEW JERSEY
Thanks Robert, I can tell the difference between a 904 and a727, If I could look at it, But it isn't near by..Just looking to buy one and wanted to know what it had before a hundred mile trip same with the rear , I just gotta look at it ..But thanks anyway !!
Edited by dynamite (11/10/17 10:02 AM)
#2401364 - 11/10/17 10:04 AM Re: 1976 Road runner [Re: dynamite]
Can you call em & have them report back what they see?
#2401401 - 11/10/17 11:45 AM Re: 1976 Road runner [Re: RapidRobert]
dynamite Offline
Loc: NEW JERSEY
Yeah thanks but this guy doesn't know the front of the car from the back..I'll have to go see it .Thanks Larry
#2401443 - 11/10/17 01:15 PM Re: 1976 Road runner [Re: dynamite]
mopars4ever Offline
Loc: md
They came both ways. Is the 360 a 4 barrel? If so I would lean towards a 727. Same with the rear axle. They came both ways but I would think the 360 came with a 8 1/4. My 77 with a 360 two barrel came with a 8 1/4 and 904 trans.
#2401457 - 11/10/17 01:46 PM Re: 1976 Road runner [Re: dynamite]
larrymopar360 Offline
Loc: Central Florida
Yep, I'm betting 8.25 rear and 904 trans.
Facts are stubborn things.
#2401804 - 11/11/17 08:21 AM Re: 1976 Road runner [Re: dynamite]
dvw Online   content
Loc: MI, usa
All 1976 360 F bodys were 2 barrel, 999 (HD904), 8 1/4. The 727 fits without issue. By changing the lower shock plates to the standard non-iso (no rubber blocks) you can bolt in a 70 and earlier B-body 8 3/4. By pulling on the springs slightly it will line up. Only 3/8" wider per side. Standard 727 A-body drive shaft will work with the 727/ 8 3/4 combo. I've owned my Super-Pak Road Runner since 1977.
Doug
#2401822 - 11/11/17 08:53 AM Re: 1976 Road runner [Re: dvw]
bboogieart Offline
Loc: Lost and Spaced
Off topic but I remember seeing later ('75? and up) B body Runners, Coronetes, and Furys. Was this a one year only thing?
When did they go to the (M-body?) Volare style?
I believe that line ended in '80.
I have mechanical Aptitude.
I can screw up anything.
#2401881 - 11/11/17 10:35 AM Re: 1976 Road runner [Re: bboogieart]
buildanother Offline
Loc: chicagoland,usa
I have a ragged 80 road runner next to my garage, and I agree, 75 was on a B body still.
#2402325 - 11/11/17 11:01 PM Re: 1976 Road runner [Re: bboogieart]
slantzilla Offline
Loc: Park Forest, IL
'75 B body Roadrunner was 1 year only. Very possibly the ugliest RR ever.
'76-80 were F bodies.
#2402474 - 11/12/17 10:48 AM Re: 1976 Road runner [Re: slantzilla]
bboogieart Offline
Very possibly the ugliest RR ever. '76-80 were F bodies.
Thanx.
Although I kinda liked the 2 door '75 B bodies, better than the '73 or '74's.
#2402973 - 11/13/17 10:06 AM Re: 1976 Road runner [Re: dynamite]
mopars4ever Offline
Loc: md
I kinda thought the 75 RR was cool also. I have always liked different.
25,485 Registered Members
192,922 Topics
1970 Satellite Station Wagon
by moparmike1
53 minutes 35 seconds ago
Check out this '65
by oldjonny
Today at 05:14 AM
Was the light package standard on Mopar convertibles?
by Grassosgarage
Today at 12:38 AM
Monster Musclecar Weekend @ Gateway
by 71yelladustr
Yesterday at 10:58 PM
