TQ plastic section #2401414
11/10/17 03:17 PM
11/10/17 03:17 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Anybody know what glue-epoxy is used to fix the jet wells back on to the Thermoquad bowl? (Where it sticks down into the base plate) White looking mixture from the factory.
Re: TQ plastic section [Re: cudaman1969] #2401576
11/10/17 09:02 PM
11/10/17 09:02 PM
I was told to use five minute epoxy years ago on anything in the cabs dealing with fuel, it worked up
Re: TQ plastic section [Re: cudaman1969] #2401676
11/11/17 12:02 AM
11/11/17 12:02 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
JB Weld wink
Re: TQ plastic section [Re: cudaman1969] #2401684
11/11/17 12:20 AM
11/11/17 12:20 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
JB weld dissolves in modern gas w alky. I used it on a gas tank where I added an additional outlet gas line. It lasted about 6 months and was completely loose.
Old Geezer Racing
Re: TQ plastic section [Re: cudaman1969] #2401777
11/11/17 09:12 AM
11/11/17 09:12 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Try marinetex.
Re: TQ plastic section [Re: quickd100] #2401856
11/11/17 12:47 PM
11/11/17 12:47 PM
moparx Offline
moparx  Offline
i was perusing the JB selection at the local ACE hardware the other day, and was surprised at the different formulas they have now for various applications. i think i saw a couple that stated they were impervious to gasoline, but i don't remember which formula they were.
beer
Re: TQ plastic section [Re: cudaman1969] #2402297
11/12/17 12:56 AM
11/12/17 12:56 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Loctite Epoxy Bond and Moroso head epoxy. You need to create a mechanical tooth on all surfaces. Also don't worry only about ethanol in pump gas. The main culprit in pump gas is BTEX. Benzene,toluene, and xylene are cheap additives in most pump gas. Alone they attack plastics and gasoline hose. As a group they are very nasty.
Re: TQ plastic section [Re: cudaman1969] #2402876
11/13/17 02:03 AM
11/13/17 02:03 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
We have less corrosive fuel down here it seems wink
Re: TQ plastic section [Re: cudaman1969] #2402931
11/13/17 11:36 AM
11/13/17 11:36 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
One note specifically about plastics. Some plastics are hard and others are soft. They all have have a vapor pressure that slowly breaks the chemical bonding. Everything is subject to it. Put that plastic in an environment that is subject to heat cycles and numerous petro chemicals and you will destroy it faster. Call Barry Grant. They are now making a TQ carb-3 BBL. See what they recommend for their phenolic bowl repair.
Re: TQ plastic section [Re: cudaman1969] #2402997
11/13/17 01:46 PM
11/13/17 01:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I'v ground/filed the factory epoxy off and used JB Weld and never any issues........... thumbs
