Strut rod mounted anti-sway bar #2401262
11/10/17 03:17 AM
11/10/17 03:17 AM
AndyF Offline OP
AndyF  Offline OP
I re-did the front anti-sway bar in this last rebuild of the Coronet. It used to be be metal on metal in all of the joints but it was really too harsh to drive on the street so I put some rubber bushings in the lower mount. The top mount is still steel on steel with no easy way to fix it.
The strut rod mount is a simple concept but difficult to actually make. I like it since it doesn't take up much space but to make it work the strut rods need to be precisely machined so the rod end can smoothly slide on the rod without a bunch of slop. Stock bars don't work so I had to have custom strut rods made. I used chrome moly bar stock and had it heat treated so it is nice and tough.
Re: Strut rod mounted anti-sway bar [Re: AndyF] #2401263
11/10/17 03:19 AM
11/10/17 03:19 AM
AndyF Offline OP
AndyF  Offline OP
The anti-sway bar is custom made from tube material. So it is big, but not very heavy. I also had it made from chrome moly and then had it heat treated so it is a spring.
Re: Strut rod mounted anti-sway bar [Re: AndyF] #2401307
11/10/17 10:17 AM
11/10/17 10:17 AM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
Whats the benefit of attaching to the arm strut and not the control arm?
1974 Roadrunner
1967 Charger
Re: Strut rod mounted anti-sway bar [Re: AndyF] #2401412
11/10/17 03:15 PM
11/10/17 03:15 PM
AndyF Offline OP
AndyF  Offline OP
The strut is already there.
Re: Strut rod mounted anti-sway bar [Re: AndyF] #2401509
11/10/17 06:34 PM
11/10/17 06:34 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
The factory thought it was a good idea for years as well.
Re: Strut rod mounted anti-sway bar [Re: AndyF] #2401521
11/10/17 07:08 PM
11/10/17 07:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Clearance for calipers up front
Don't be the exception.
Re: Strut rod mounted anti-sway bar [Re: AndyF] #2401809
11/11/17 11:28 AM
11/11/17 11:28 AM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
Better motion ratio as well since it is mounted further out on the arm.
Re: Strut rod mounted anti-sway bar [Re: AndyF] #2403331
11/14/17 12:42 AM
11/14/17 12:42 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
We look at the arm as a strut but once it's all bolted together, it is effectively an A arm.
