1976 Road runner #2401315
11/10/17 11:01 AM
11/10/17 11:01 AM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
On a 1976 Volare .Road Runner edition, with 360 and t- flight,, what trans 904 or A- 727.. and what rear .. 8. 1/4 ???Thanks for any help ....
Re: 1976 Road runner [Re: dynamite] #2401330
11/10/17 11:54 AM
11/10/17 11:54 AM
by the dist, look down along the top sloped bellhousing of the trans & if there is a circular "bump" all the way around the trans case down where the angle starts to turn back horizontle then it is a 904 or look at the pan & if it is a square with a corner cutout then it is a 904 (727 has a dogleg). On the rear, count the bolts on the center section & are they in front or rear. 7&1/4 has a bolt on rear cover with 9 or 10 bolts & it (the cover) looks like a mini Dana. iirc the 8&1/4 is an oval shaped bolt on.
Re: 1976 Road runner [Re: RapidRobert] #2401362
11/10/17 01:00 PM
11/10/17 01:00 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Thanks Robert, I can tell the difference between a 904 and a727, If I could look at it, But it isn't near by..Just looking to buy one and wanted to know what it had before a hundred mile trip same with the rear , I just gotta look at it ..But thanks anyway !!
Re: 1976 Road runner [Re: dynamite] #2401364
11/10/17 01:04 PM
11/10/17 01:04 PM
Can you call em & have them report back what they see?
Re: 1976 Road runner [Re: RapidRobert] #2401401
11/10/17 02:45 PM
11/10/17 02:45 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Yeah thanks but this guy doesn't know the front of the car from the back..I'll have to go see it .Thanks Larry
Re: 1976 Road runner [Re: dynamite] #2401443
11/10/17 04:15 PM
11/10/17 04:15 PM
md
mopars4ever Offline
mopars4ever  Offline
md
They came both ways. Is the 360 a 4 barrel? If so I would lean towards a 727. Same with the rear axle. They came both ways but I would think the 360 came with a 8 1/4. My 77 with a 360 two barrel came with a 8 1/4 and 904 trans.
Re: 1976 Road runner [Re: dynamite] #2401457
11/10/17 04:46 PM
11/10/17 04:46 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Yep, I'm betting 8.25 rear and 904 trans.
Facts are stubborn things.
Re: 1976 Road runner [Re: dynamite] #2401804
11/11/17 11:21 AM
11/11/17 11:21 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
All 1976 360 F bodys were 2 barrel, 999 (HD904), 8 1/4. The 727 fits without issue. By changing the lower shock plates to the standard non-iso (no rubber blocks) you can bolt in a 70 and earlier B-body 8 3/4. By pulling on the springs slightly it will line up. Only 3/8" wider per side. Standard 727 A-body drive shaft will work with the 727/ 8 3/4 combo. I've owned my Super-Pak Road Runner since 1977.
Doug
Re: 1976 Road runner [Re: dvw] #2401822
11/11/17 11:53 AM
11/11/17 11:53 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Off topic but I remember seeing later ('75? and up) B body Runners, Coronetes, and Furys. Was this a one year only thing?
When did they go to the (M-body?) Volare style?
I believe that line ended in '80.
I have mechanical Aptitude.
I can screw up anything.
Re: 1976 Road runner [Re: bboogieart] #2401881
11/11/17 01:35 PM
11/11/17 01:35 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I have a ragged 80 road runner next to my garage, and I agree, 75 was on a B body still.
Re: 1976 Road runner [Re: bboogieart] #2402325
11/12/17 02:01 AM
11/12/17 02:01 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
'75 B body Roadrunner was 1 year only. Very possibly the ugliest RR ever.
'76-80 were F bodies.
Re: 1976 Road runner [Re: slantzilla] #2402474
11/12/17 01:48 PM
11/12/17 01:48 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Very possibly the ugliest RR ever. '76-80 were F bodies.
Thanx.
Although I kinda liked the 2 door '75 B bodies, better than the '73 or '74's.
Re: 1976 Road runner [Re: dynamite] #2402973
11/13/17 01:06 PM
11/13/17 01:06 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I kinda thought the 75 RR was cool also. I have always liked different.
