#2401262 - 11/10/17 12:17 AM Strut rod mounted anti-sway bar
AndyF Offline
Loc: Oregon
I re-did the front anti-sway bar in this last rebuild of the Coronet. It used to be be metal on metal in all of the joints but it was really too harsh to drive on the street so I put some rubber bushings in the lower mount. The top mount is still steel on steel with no easy way to fix it.
The strut rod mount is a simple concept but difficult to actually make. I like it since it doesn't take up much space but to make it work the strut rods need to be precisely machined so the rod end can smoothly slide on the rod without a bunch of slop. Stock bars don't work so I had to have custom strut rods made. I used chrome moly bar stock and had it heat treated so it is nice and tough.
#2401263 - 11/10/17 12:19 AM Re: Strut rod mounted anti-sway bar [Re: AndyF]
AndyF Offline
Loc: Oregon
The anti-sway bar is custom made from tube material. So it is big, but not very heavy. I also had it made from chrome moly and then had it heat treated so it is a spring.
#2401307 - 11/10/17 07:17 AM Re: Strut rod mounted anti-sway bar [Re: AndyF]
Saskabusa Offline
Loc: Scatchamatoon
Whats the benefit of attaching to the arm strut and not the control arm?
Edited by Saskabusa (11/10/17 07:17 AM)
1974 Roadrunner
1967 Charger
#2401412 - 11/10/17 12:15 PM Re: Strut rod mounted anti-sway bar [Re: AndyF]
AndyF Offline
Loc: Oregon
The strut is already there.
#2401509 - 11/10/17 03:34 PM Re: Strut rod mounted anti-sway bar [Re: AndyF]
BigBlockMopar Offline
Loc: The Netherlands
The factory thought it was a good idea for years as well.
BigBlockMopar.com
#2401521 - 11/10/17 04:08 PM Re: Strut rod mounted anti-sway bar [Re: AndyF]
Supercuda Offline
Clearance for calipers up front
#2401809 - 11/11/17 08:28 AM Re: Strut rod mounted anti-sway bar [Re: AndyF]
73MagDuster Offline
Loc: Hershey, PA
Better motion ratio as well since it is mounted further out on the arm.
#2403331 - 11/13/17 09:42 PM Re: Strut rod mounted anti-sway bar [Re: AndyF]
Magnum Offline
Loc: Hamilton, Ontario Canada
We look at the arm as a strut but once it's all bolted together, it is effectively an A arm.
25,351 Registered Members
190,310 Topics
Reccomend A 4-Link Kit 70 Cuda
by Wolfeman78
06/24/18 12:41 PM
early crew cab
by azmopar
06/24/18 12:27 PM
GTX gas pedal bolt location
by tweeter1
06/24/18 12:00 PM
1969 Charger taillights
by road
06/24/18 11:55 AM
