Re: 440 Daily Driver
[Re: Nick Stev]
#2401526
11/10/17 07:18 PM
11/10/17 07:18 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The Eddy is a fine carb for daily use on cammed 440s. I ran one for a couple decades.
The build sounds okay and I'd agree with the suggested RPM intake.
My 65 Plymouth with the twin turbo 440 pulled down 19+ mpg on the highway with the overdrive transmission. MPG dropped when I went back to an automatic. If I recall correctly, I got around 14-15 mpg in the city.
[Re: topside]
#2401587
11/10/17 09:26 PM
11/10/17 09:26 PM
Posts: 16,128 Mesa, Arizona
dart4forte
Mesa, Arizona
I'd buy the crank from Eagle or Scat or 440Source, not Mopar. I like the more-stock-appearing 440Source Stealth heads; I'm kinda sneaky like that...likewise the Eddy dual-plane after grinding off the name. I'd also prefer either an Eddy or a Thermoquad for carb duty, better MPG than a Holley in my experience, though the Holleys are easier to tune. Check the Archives here for pages of 440 builds, and mind the compression ratios, quench, timing & cooling advice and you'll be fine & happy. If you need a crank & pistons, the hardest part is resisting the temptation for more stroke... Consider a FI setup such as FITEC
Abe Lincoln
[Re: Nick Stev]
#2401593
11/10/17 09:46 PM
11/10/17 09:46 PM
feets
Senior Management
Senior Management
Irving, TX
FiTec is what I'm planning for my Imperial.
[Re: minivan]
#2401658
11/10/17 11:40 PM
11/10/17 11:40 PM
Posts: 5 NC
Nick Stev
NC
Edelbrock Performer RPM dual plane intake would make a nice addition to the package. Avoid the low RPM dead spot and skip the Edelbrock carb. They are great on many engines, but not a 440 with a little bit of cam. I actually have an edelbrock performer (not the RPM) i forgot to mention it because it came with the car.
[Re: Nick Stev]
#2401699
11/11/17 12:58 AM
11/11/17 12:58 AM
Posts: 1,004 Central US
grancuda
Central US
Why the -6 pistons & 84cc heads? Why not flat tops & 74cc heads?
1967 Barracuda Formula S 383 1967 Chevy C10 Short Stepper 1980 Macho Power Wagon LWB 318 2021 Toyota Supra
[Re: minivan]
#2401706
11/11/17 01:10 AM
11/11/17 01:10 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Never had a 440 that averaged much better than 6 mpg.. I know, I know, someone on here gets 22 mpg with there 440.. Yeah right...
If you haven't driven a car that gets 6 mpg recently, the fuel gauge moves about like a tach needle does... Really quickly.... I had a 68 Charger R/T 440 automatic with 3.23 sure grip. Running Union 76 Leaded 93 Octane I got a best 11.9MPG. That was in 1984 and I had to baby it to get it
[Re: grancuda]
#2401818
11/11/17 11:46 AM
11/11/17 11:46 AM
Posts: 4,310 Prospect, PA
BSB67
Prospect, PA
Why the -6 pistons & 84cc heads? Why not flat tops & 74cc heads? If it is a 2.06" CD piston, zero decked, it would probably be about perfect with a 84 cc head, going from memory.
[Re: Nick Stev]
#2401831
11/11/17 12:13 PM
11/11/17 12:13 PM
Posts: 11,996 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
As with any new combo, it will probably take a while to work all the kinks out and get it optimized. So be prepared with a back-up plan for the unavoidable down time that will surely happen. Personally, using any specialty vehicle as a DD takes some of the magic away. Especially when you have to work on it just to get to work or the grocery store. At his point in time, it is often unrealistic to expect to use our half century old dinosaurs for dependable daily transportation. Then there's the safety factor. (Air bags/SRS/ABS/etc) Good luck.
Master, again and still
[Re: Nick Stev]
#2401832
11/11/17 12:15 PM
11/11/17 12:15 PM
BSB67
Prospect, PA
I was wondering what everyone thinks of this build for a daily driver that I’ll take to the strip once in awhile: Mopar performance (or eagle) forged crankshaft: 3.750 stroke, internally balanced SRP 440 forged pistons: 4.350 bore, -6.00cc Edelbrock performer RPM heads: 84cc Comp cams hydraulic flat tappet xe268h: 268/280 duration Hedman elite headers Some type of vacuum secondary carb (maybe around 750-850 cfm) TKO-600 with .82 overdrive Dennys driveshaft (wondering if i would need a 3 in or 3.5 in) 3.55 rear end with detroit truetrac differential Assuming you're using one one of SRP 2.062" CD pistons, I like what you're planning for a true driver that you are intending. I would consider using the std Performer intake, or the factory spreadbore intake with a spreadbore style carb. I have done this on a build very very similar to yours. You might give up a couple hp, but the daily drive characteristics are phenomenal.
[Re: DaveRS23]
#2401845
11/11/17 12:33 PM
11/11/17 12:33 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
At this point in time, it is often unrealistic to expect to use our half century old dinosaurs for dependable daily transportation.
Parts availability can be an issue for the unexpected mishap. When properly maintained these cars gave great service. Personally I use a '76 P/U for regular service through out the year. I keep it maintained myself. I have also always had a back up, just in case. Do you have room for two cars? Any car can leave you stranded. I prefer one I understand and can work on myself. If you can't, it is very hard to find some one that knows how to work on vintage tin. It all depends on your knowledge, ability and willingness to keep it running. Mileage? I assume you are aware of the limits here. My vote? Go 4 it.
I have mechanical Aptitude. I can screw up anything.
[Re: feets]
#2401848
11/11/17 12:39 PM
11/11/17 12:39 PM
Posts: 1,643 A certified culture free zone.
74RALLYE
My 65 Plymouth with the twin turbo 440 pulled down 19+ mpg on the highway with the overdrive transmission. MPG dropped when I went back to an automatic. If I recall correctly, I got around 14-15 mpg in the city. For every person that says they had good results with the Edelbrock 750 or 800 on a normally aspirated 440,there's 10 that didn't. I've used the 750 and 800 on warmed over 440s and found that unless the timing is dialed way back, the only fix is a different brand carb. Try doing a search for "Edelbrock off idle stumble/dead spot", It's a common problem.
