Why do my brakes keep un-adjusting?
#2401172
11/09/17 10:51 PM
11/09/17 10:51 PM
Posts: 4,179 California
mickm
California
70 Road runner, stock 11" drums. Front left continually adjusts looser over time, and fairly quickly. I set it so there is enough drag to get about a turn when I spin the tire, and w/in 20-30 miles it's loose again. More than about 100 miles and it's dangerous, that side is so loose that when I hit the brakes it pulls sharply to the right. Adjust it out and everything is ok.
I just had it apart, and confirmed it is a left hand adjuster. I double checked that everything is connected correctly, and took a pry bar and moved the rear shoe back at the top, and it did click the adjustor. I double checked that it is going in the right direction, i.e. when the adjuster is turned, it is expanding and not contracting.
Had a mopar friend take a look, and he saw nothing wrong either.
What could be causing this?
Re: Why do my brakes keep un-adjusting?
[Re: mickm]
#2401177
11/09/17 11:03 PM
11/09/17 11:03 PM
Posts: 96,649 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Is the spring laying against the star so the star doesn't turn from vibration?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: mickm]
#2401186
11/09/17 11:20 PM
11/09/17 11:20 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Best picture I have of the layout from the FSM
[Re: amxautox]
#2401192
11/09/17 11:34 PM
11/09/17 11:34 PM
RapidRobert
Is the spring laying against the star so the star doesn't turn from vibration? that is what I would confirm & compare the tang/teeth etc on the adjuster assy on both sides to see if they are identical (other than the mirror images/different twist on the threads). The tang somehow has to be improperly allowing the star wheel teeth to vibrate/move for it to be loosening.
[Re: mickm]
#2401392
11/10/17 02:14 PM
11/10/17 02:14 PM
amxautox
Also make sure the adjuster is inserted in place in the proper orientation. If swapped end for end the adjuster cable and plate will turn the adjuster the wrong way, and make the shoes move AWAY from the drums instead of TOWARDS the drums.
Tom
author unknown
[Re: amxautox]
#2401399
11/10/17 02:43 PM
11/10/17 02:43 PM
Posts: 16,131 Mesa, Arizona
dart4forte
Mesa, Arizona
Also make sure the adjuster is inserted in place in the proper orientation. If swapped end for end the adjuster cable and plate will turn the adjuster the wrong way, and make the shoes move AWAY from the drums instead of TOWARDS the drums. Sounds like the adjuster is backakwards
Abe Lincoln
[Re: dart4forte]
#2401426
11/10/17 03:43 PM
11/10/17 03:43 PM
mickm
California
Also make sure the adjuster is inserted in place in the proper orientation. If swapped end for end the adjuster cable and plate will turn the adjuster the wrong way, and make the shoes move AWAY from the drums instead of TOWARDS the drums. Sounds like the adjuster is backakwards I won't be able to get pictures until this weekend, but I 1) made sure this was a left side adjustor, 2) matched the position of all the components with the diagram in the FSM, 3) turned the adjuster by hand to make sure it was going in the right direction, and 4) then pried the rear shoe away from the perch, and it did move the adjustor, which I once again verified was the correct direction. doesn't mean I didn't miss something, but I think all of that is good.
[Re: dart4forte]
#2401464
11/10/17 05:03 PM
11/10/17 05:03 PM
Posts: 1,820 South Bend
John Brown
South Bend
Also make sure the adjuster is inserted in place in the proper orientation. If swapped end for end the adjuster cable and plate will turn the adjuster the wrong way, and make the shoes move AWAY from the drums instead of TOWARDS the drums. Sounds like the adjuster is backakwards Or swapped side for side.....
[Re: mickm]
#2401491
11/10/17 05:52 PM
11/10/17 05:52 PM
Posts: 25,741 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You are aware that the self-adjusters only work when the brakes are firmly applied when backing up?
Lots of folks shift to Drive after backing up and seldom/never use the brakes.
[Re: John_Kunkel]
#2401500
11/10/17 06:10 PM
11/10/17 06:10 PM
mickm
California
Lots of folks shift to Drive after backing up and seldom/never use the brakes. Yes, that's why I pried the rear shoe away from the top mount. And as mentioned, it worked as expected.
[Re: mickm]
#2401716
11/11/17 01:30 AM
11/11/17 01:30 AM
Posts: 954 garnett kansas
rhad
garnett kansas
does the spring set down tight against the star wheel?
my ladder of success is missing some rungs
[Re: rhad]
#2401875
11/11/17 01:21 PM
11/11/17 01:21 PM
RapidRobert
if nothing appears bent/out of place/not working/wrong parts you might pull the drum & have a helper work the pedal BARELY so the shoes expand a slight bit then let off & repeat & see if the star wheel starts expanding the shoes. work with him so he goes just far enough for the tang to catch the next tooth. Holler what it ends up being.
[Re: RapidRobert]
#2401912
11/11/17 02:39 PM
11/11/17 02:39 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
if nothing appears bent/out of place/not working/wrong parts you might pull the drum & have a helper work the pedal BARELY so the shoes expand a slight bit then let off & repeat & see if the star wheel starts expanding the shoes. work with him so he goes just far enough for the tang to catch the next tooth. Holler what it ends up being. Keyword here is BARELY, unless you want brake cylinder pistons all over your shop... Did some stupid things when I was young.... LOL
