Page 2 of 7 1 2 3 4 5 6 7
Re: are oversize hyd lifters available? 360 SB [Re: BSB67] #2401037
11/09/17 04:27 PM
11/09/17 04:27 PM
RapidRobert Offline OP
From the "partsvoice" search: #1 3549990 (.001). #2 3004644. #3 3614321. #4 4049338. #5 3549991 (.008"). I ain't sure what the descrip of 2,3 & 4 are. CJ motorsports has (14) of #1 and none of #5. "collectors" has (11) of #1 (4) of #2 (9) of #3 (6) of #4 (0) of #5. Brads NOS parts west columbia south carolina Chrysler has 1 of #1. none of #2. (9) of #3. none of #4. none of #5. Silkis (sp) auto parts in jacksonville florida has none of #1 #2 #5 and (8) of #3 and (9) of #4. I am waiting to hear back from Paul at Hylift johnson. lambert auto sales in claremont new hampshire has none of #1 #2 #3 #5 and (14) of #4 EDIT So CJ has (14) .001" and "collectors" has (11) .001" and Brads has (1) .001" & I will post what Hylift Johnson has to say when he calls. No (.008") as of yet
Re: are oversize hyd lifters available? 360 SB [Re: BSB67] #2401064
11/09/17 05:27 PM
11/09/17 05:27 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
How is .016 equal to .025? I am not that familiar with small blocks and really never liked the stock lifter, pushrod geometry. I would imagine with all that crazy side load that the lifter bores will wear out on these? I've never seen a lifter that felt "loose" in its bore but again I have BB's. I would imagine that as soon as the lifters started getting loose in their bores that they could really start wobbling the hole out pretty substantially. If they do wear out enough to cause a pressure loss, wouldn't it be a good idea to get them bushed? The bushing will provide the correct pressure even if after time it wears out of spec.
Re: are oversize hyd lifters available? 360 SB [Re: Dave Hall] #2401073
11/09/17 05:48 PM
11/09/17 05:48 PM
What happened is I overhoned the bores (brake hone grit was too rough) & now I would like to see if some OS lifters would restore a good amt of the psi & I direct fed the heads with a .060" orifice on both sides (I need to reduce that right now which may take care of some or all of the problem) plus the head gasket cooling hole additions/mods to "supposedly" improve the cooling system (& there was no issue to being with! so this being the 5th fireup to resolve the HG issue (& it was OK this time) I would like to take care of the oiling WO another teardown. I kinda lost my head on this eng. I'm gonna do the math on the area of a .001 reduction X 16 & see what I come up with but not right now. thanks guys. RR
Re: are oversize hyd lifters available? 360 SB [Re: RapidRobert] #2401074
11/09/17 05:54 PM
11/09/17 05:54 PM
P
Paul_Fancsali Offline
P
Use 20-50wt oil and lot of the slop will be handled do no use 5 w any thing. But if you know the bores are off you should go with having them bushed
Re: are oversize hyd lifters available? 360 SB [Re: Paul_Fancsali] #2401080
11/09/17 06:08 PM
11/09/17 06:08 PM
Paul that is an excellent thought that never crossed my mind!. I have bradd Penn breakin oil in there now which I ain't sure what the weight is but it is/poured real thin & I go with BP "regular" after that but I forgot the weight he usually sells me. Ok I'm gonna get some .001 lifters/reduce the head direct feeds from .060 to .030 (maybe .040) & get some thick oil in there. it will cost me some horsepower but a non issue if it keeps from haveing to tear down this monster again. I feel lucky (all of a sudden).
Re: are oversize hyd lifters available? 360 SB [Re: dogdays] #2401086
11/09/17 06:31 PM
11/09/17 06:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By dogdays
The phone number listed above is for Rurallife magazine, published by the same company that gave us Farm Journal and The Dakota Farmer. How could they be a lifter manufacturer?
Current number for Hylift Johnson is:
Sales and Service: (800) 441-1400 ext 500
Re: are oversize hyd lifters available? 360 SB [Re: RapidRobert] #2401088
11/09/17 06:35 PM
11/09/17 06:35 PM
P
P
Just remember that 20-50 is heavy on a 10 degree day I just don't start the engines in that weather if possible. I had to do it one year due to sewer issue So i hunted for a oil dip[stick heater worked like a charm
Re: are oversize hyd lifters available? 360 SB [Re: Paul_Fancsali] #2401091
11/09/17 06:38 PM
11/09/17 06:38 PM
Another dynamite idea, bro you have outdid yourself today!
Re: are oversize hyd lifters available? 360 SB [Re: RapidRobert] #2401205
11/10/17 12:36 AM
11/10/17 12:36 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Damn! Now I'm confused if I have hilift johnson or Johnson lifters... btw johnson lifters doesn't have them ( just got the reply to my email request )
Re: are oversize hyd lifters available? 360 SB [Re: Dave Hall] #2401208
11/10/17 12:43 AM
11/10/17 12:43 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
.25" dia. Hole, not .025 clearance. Do you really want me to show the math? I will if you like. Maybe I made a mistake.
I don't get the sense this is a high end build. Measuring stuff could be an option too. Silly right
Re: are oversize hyd lifters available? 360 SB [Re: BSB67] #2401365
11/10/17 01:08 PM
11/10/17 01:08 PM
I just got off the ph with Hylift Johnson & they have the .008" for $300 to my door & Central Jersey motorsports has .001" for $155 to my door
Re: are oversize hyd lifters available? 360 SB [Re: RapidRobert] #2401390
11/10/17 02:10 PM
11/10/17 02:10 PM
So. Burlington, Vt.
fast68plymouth Online content
fast68plymouth  Online Content
So. Burlington, Vt.
The difference in area between .904 and .905, 16 times, is .02272sq/in.
This is equal to about one .170" diameter hole(.02269sq/in).
That's a pretty big leak.
Measure???
What a novel idea!!
Re: are oversize hyd lifters available? 360 SB [Re: RapidRobert] #2401411
11/10/17 03:11 PM
11/10/17 03:11 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
WHAAAAAT ?
( BTW, just confirmed the ones on my block are HLJ lifters )
HLJ brand ? or which brand ?
Re: are oversize hyd lifters available? 360 SB [Re: RapidRobert] #2401451
11/10/17 04:35 PM
11/10/17 04:35 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Nacho, they were NOS mopar lifters from CJM.
Re: are oversize hyd lifters available? 360 SB [Re: NachoRT74] #2401486
11/10/17 05:35 PM
11/10/17 05:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Johnson and Hylift Johnson are two different companies.
Re: are oversize hyd lifters available? 360 SB [Re: RapidRobert] #2401495
11/10/17 06:01 PM
11/10/17 06:01 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
mopars4ever
good
John_Kunkel
yes I know, just was confused which ones I had... and remembered later they are HLJ ones ( the ones from toplineauto )
RapidRobert
got the reply from Topline crew and you are right on the price... damn that's expensive!!!
Re: are oversize hyd lifters available? 360 SB [Re: RapidRobert] #2401502
11/10/17 06:18 PM
11/10/17 06:18 PM
P
Porter67 Offline
Porter67  Offline
P
Have you considered vs throwing lifter money at a so so maybe fix, it just might be cheaper in the long run to machine a different old block?
Re: are oversize hyd lifters available? 360 SB [Re: NachoRT74] #2401514
11/10/17 06:45 PM
11/10/17 06:45 PM
68plymouth, yes measureing would be dead on but I am going to get the .001's & swap em in thru the openings in the heads then finish the cam breakin & I know they wont be too tight. If I pulled the intake I could measure & maybe even the .008's would be required but I dont want to pull it as I am so close on this eng from Hell & I think between the .001" OS lifters & reduceing the .060 feeds to the heads that I (hopefully) can get my oil psi up in a good range. John Kunkel, the "Johnson" # I called was 1-800-441-1400. Nacho I have another loose block but for 3 bills when the time comes I might just have it bushed & run std lifters. EV2bird, point taken but on this deal now that it is in/running/head gaskets are sealing, if I can get it finished "reasonably" acceptable WO another teardown I will consider it a victory. with all the plumbing etc on this one it ain't fun (& this is fireup #5!).
Re: are oversize hyd lifters available? 360 SB [Re: RapidRobert] #2401537
11/10/17 07:45 PM
11/10/17 07:45 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Robert, do you have a lifter tool? I have a couple of them.
Re: are oversize hyd lifters available? 360 SB [Re: mopars4ever] #2401541
11/10/17 07:53 PM
11/10/17 07:53 PM
Mopars4ever, if you mean a magnet yes I have a tailor made one on a long telescoping shaft that extends & one opening on the head was just big enough to get the lifter thru (I had to take one out). I got a feeling that my HF borescope will (finally) start paying for itself on this deal!
