Re: 1100 Dominator boosters
[Re: mopar dave]
#2400826
11/09/17 01:52 AM
11/09/17 01:52 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I know relatively nothing about carbs...... but I’m pretty sure it has nothing to do with RPM, it has to do with vacuum signal. Free-revving a motor is not going to pull a much vacuum. Thus, boosters may not be drawing much fuel.
We need Dom......
[Re: StealthWedge67]
#2400852
11/09/17 03:13 AM
11/09/17 03:13 AM
Posts: 304 Florida
Mark Whitener
We need Dom...... Booster start point is controlled by the signal generated by the booster, the amount of emulsion/kill bleed above float level, float level, and the main air bleed size. The same carb on two different engines may start booster flow at different RPM's as the pressure difference may not be the same at the same RPM.
Mark Whitener [url=www.racingfuelsystems.com[/url]
[Re: mopar dave]
#2401151
11/09/17 10:02 PM
11/09/17 10:02 PM
Posts: 4,457 Washington
madscientist
Washington
Did you buy and install an O2 sensor?
If you did, do you mind posting what the O2 said before and after you added fuel??
Thanks.
