Re: Natural Finish on Tie Rods
[Re: screamindriver]
#2400343
11/08/17 04:56 AM
11/08/17 04:56 AM
Posts: 784 Florida
cbusters
If you're going the paint route here's the trick...Spray it with a light color first..Go heavy with this coat to give you the coverage/weather resistance you need to keep it looking fresh...Let that coat flash and then add a darker color as a mist coat..This is the coat you can use as a tint to get that dark,forged color it needs to be...You can actually use more than one color to tint the part if desired to get that "as forged" look... After the part completely dries use a scotchbrite pad to LIGHTLY scuff and highlight the part to bring out the casting grain,parting line,and other details as needed... Here's an example using the technique...Eastwoods Zinc phosphate paint was used as the dark tint on this part is adds a nice charcoal tone to the part... That's the look! Impressive.
[Re: cbusters]
#2400796
11/09/17 12:43 AM
11/09/17 12:43 AM
Posts: 3,391 cheshire, ct
davesmopars
cheshire, ct
Supper nice job! I like the look
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: B5 Bee]
#2400888
11/09/17 09:54 AM
11/09/17 09:54 AM
Posts: 784 Florida
cbusters
It's a shame beautiful detail work like that will be seen by few. I think detail work like that is mainly for the person doing it. I have a finished car that has the copper colored left-hand wheel studs and green paint swipes across the spindle hubs. I never pull the dog dishes, but I know they are there. Most that look at the car are clueless about what is under the surface. But they get to say, "I had one just like this...". It looks like the color is pretty close, just missing a dusting of rust color.
[Re: cbusters]
#2400902
11/09/17 11:03 AM
11/09/17 11:03 AM
Posts: 1,811 South Bend
John Brown
South Bend
Copper spray paint lightly dusted comes close to rust when sprayed from about two feet away, says fullmetaljacket.
