#2399320 - 11/06/17 10:30 AM 5.7 and the 727 pb
csmopar Offline
Loc: usa
I've been trying to determine if a 5.7 hemi can mate to a small block 727 pushbutton. Has anyone tried this?
#2399391 - 11/06/17 12:09 PM Re: 5.7 and the 727 pb [Re: csmopar]
hudsonhornet7x Offline
Loc: Plumer, Pa
It will bolt right up. You just need the correct flex plate.
XP29H8B198192
#2399504 - 11/06/17 03:40 PM Re: 5.7 and the 727 pb [Re: hudsonhornet7x]
sam64 Offline
Loc: okla.
if it is pre 1965 I think the bottom pass.bolt will not line up,other than that it will work.
10.86@123
#2399513 - 11/06/17 03:57 PM Re: 5.7 and the 727 pb [Re: hudsonhornet7x]
csmopar Offline
Loc: usa
Sweet thanks
#2399514 - 11/06/17 03:57 PM Re: 5.7 and the 727 pb [Re: sam64]
csmopar Offline
Loc: usa
It's a 64
#2399550 - 11/06/17 04:55 PM Re: 5.7 and the 727 pb [Re: csmopar]
moparpollack Online   penguin-006
Loc: 85086
Are the bolts that go into the block metric?
67 Coronet, 68 Roadrunner, 69 Super Bee, 69 Coronet 500 convertible, 70 Roadrunner Post, 79 D150 360, and a severe case of Mopar a,d,d
#2399624 - 11/06/17 07:01 PM Re: 5.7 and the 727 pb [Re: csmopar]
RTSE4ME Offline
Loc: MD
No, 3/8-16 thread I used the small block ARP bellhousing bolt kit
#2399625 - 11/06/17 07:01 PM Re: 5.7 and the 727 pb [Re: csmopar]
savoy64 Offline
Loc: colorado
you also need that thin spacer that goes to the block---or there is a new torque converter being made to allow for that thickness....
#2399645 - 11/06/17 07:20 PM Re: 5.7 and the 727 pb [Re: savoy64]
moparmitch Offline
Loc: Michigan
What's the thickness? I assume a mid-plate could take care of this?
Edited by moparmitch (11/06/17 07:44 PM)
#2399654 - 11/06/17 07:33 PM Re: 5.7 and the 727 pb [Re: csmopar]
cudadoug Offline
Loc: Between a rock & a hard place
Doesn't the right flex plate eliminate the need for any spacers?
#2399670 - 11/06/17 07:57 PM Re: 5.7 and the 727 pb [Re: cudadoug]
sam64 Offline
Loc: okla.
some of the first flex plate conversions used a spacer between the block and trans.because the flex plate was flat.
10.86@123
#2399901 - 11/07/17 09:24 AM Re: 5.7 and the 727 pb [Re: sam64]
csmopar Offline
Loc: usa
awesome thanks
#2400154 - 11/07/17 05:51 PM Re: 5.7 and the 727 pb [Re: csmopar]
savoy64 Offline
Loc: colorado
the spacer looks like 3/64? and is used on the 5.7 and the 4.7-----a friend has done 4 of these into older mopars and has bought these off ebay i believe----i grabbed a junkyard one for him and he announced he got a torque converter that was made to delete the need for that spacer....someone here must be up on it......mopar part number 53032454AA.
Edited by savoy64 (11/07/17 06:51 PM)
#2402449 - 11/12/17 10:09 AM Re: 5.7 and the 727 pb [Re: csmopar]
C_B5 Offline
Loc: Ohio
Related question - Are you planning to retain the pushbuttons to shift the trans ?
I would be interested in knowing what cable set-up you're using to connect the pushbutton to the trans.
25,246 Registered Members
188,817 Topics
Mini bikes
by f8-4life
12 minutes 56 seconds ago
Dumb question about keeping track of VIN numbers bitd
by Neil
42 minutes 2 seconds ago
what are the odds 2 54 Dodge Indy 500 HEMI
by theraif
46 minutes 22 seconds ago
That didn't go as planned
by feets
Today at 04:56 PM
