Page 2 of 26 1 2 3 4 25 26
Re: My 63 Dodge 330 Project: #428217
11/08/09 09:19 PM
11/08/09 09:19 PM
Anonymous OP
Anonymous OP
Nother of the fender:
Re: My 63 Dodge 330 Project: #428218
11/08/09 09:20 PM
11/08/09 09:20 PM
Anonymous OP
Anonymous OP
Engine Compartment:
You can't really tell but passenger fender is bolted on with stainless fasteners to clean up the engine compartment.
Re: My 63 Dodge 330 Project: #428219
11/08/09 09:23 PM
11/08/09 09:23 PM
Anonymous OP
Anonymous OP
Close up of engine.
Carb needs a spacer for the throttle linkage to properly clear the intake.
Re: My 63 Dodge 330 Project: #428220
11/08/09 09:30 PM
11/08/09 09:30 PM
Anonymous OP
Anonymous OP
Superstock springs #456 and #457. New tank, brake lines etc. soon...
Re: My 63 Dodge 330 Project: #428221
11/08/09 09:31 PM
11/08/09 09:31 PM
Anonymous OP
Anonymous OP
New tank:
Re: My 63 Dodge 330 Project: #428222
11/08/09 09:33 PM
11/08/09 09:33 PM
Anonymous OP
Anonymous OP
Cheetah full manual valvebody and Turbo Action convertor soon to be installed in transmission(no pics).
New 3.55 gearset with suregrip with 742 case sitting here still wrapped up. More new pics soon!
Re: My 63 Dodge 330 Project: #428223
11/11/09 03:34 PM
11/11/09 03:34 PM
Anonymous OP
Anonymous OP
'nother "pig" shot:
Re: My 63 Dodge 330 Project: #428224
11/11/09 03:37 PM
11/11/09 03:37 PM
Anonymous OP
Anonymous OP
FedEx just dropped off the seat brackets this morning:
Got them at a great deal through Moparcrazy.com!
Re: My 63 Dodge 330 Project: #428225
11/11/09 03:37 PM
11/11/09 03:37 PM
Anonymous OP
Anonymous OP
Inner bracket:
Interior should be back from upholstry sometime next week!
Re: My 63 Dodge 330 Project: #428226
11/12/09 04:23 PM
11/12/09 04:23 PM
Anonymous OP
Anonymous OP
Finished off rebuilding the transmission today and installed a Cheetah pro-street full manual valvebody.
(bands weren't adjusted yet so no, I didn't forget to tighten the lock nut on the rear one....)
Re: My 63 Dodge 330 Project: #428227
11/12/09 04:24 PM
11/12/09 04:24 PM
Anonymous OP
Anonymous OP
valvebody:
Re: My 63 Dodge 330 Project: #428228
11/12/09 04:28 PM
11/12/09 04:28 PM
Anonymous OP
Anonymous OP
Outer case and rear mount from Imperial Services that adapts early body mount to later 727. I blasted and painted the mount inself (nasty and full of crud!)
Re: My 63 Dodge 330 Project: #428229
11/12/09 04:29 PM
11/12/09 04:29 PM
Anonymous OP
Anonymous OP
That's all for now.....
I need to pull the engine back out to clearance the front K--frame for the deep sump oil pan. After that I can put the engine and trans in and hopefully it'll be the final time.
The great part about this project is I'm doing 99.5% of the work myself! Having the seats re-covered is the only thing that I'm really farming out to someone else. That and the machine work on the engine.
Re: My 63 Dodge 330 Project: #428230
11/25/09 03:43 PM
11/25/09 03:43 PM
Anonymous OP
Anonymous OP
Safety wired Wilwood rotors:
Re: My 63 Dodge 330 Project: #428231
11/25/09 03:47 PM
11/25/09 03:47 PM
Anonymous OP
Anonymous OP
Fuel tank, rear springs, and 3rd member all installed. Just need drum brakes rebuilt to finish off the rear.
Re: My 63 Dodge 330 Project: #428232
11/25/09 03:49 PM
11/25/09 03:49 PM
Anonymous OP
Anonymous OP
15x8 steelies from Summit to go on the rear:
Re: My 63 Dodge 330 Project: #428233
11/25/09 03:55 PM
11/25/09 03:55 PM
Anonymous OP
Anonymous OP
Side shot of the car in the garage:
Some people have asked why it's going back together without the final coat of paint on it. Couple of reasons:
1. I think the flat black is sinister especially on this body style.
2. I want to fully shake down the car, check for oil leaks, and basically make sure everything is perfect before final paint.
3. Next winter I'll blow the car apart and do it up in gloss black. I still haven't given the undercarriage the attention it deserves so next winter will be the time for that as well.
Re: My 63 Dodge 330 Project: #428234
11/25/09 05:45 PM
11/25/09 05:45 PM
Anonymous OP
Anonymous OP
Nice job, I like the idea of stainless fasteners. The car does have that look in black primer.
Re: My 63 Dodge 330 Project: [Re: ] #428235
12/03/09 12:55 AM
12/03/09 12:55 AM
Anonymous OP
Anonymous OP
Pulled the motor back out to install the flexplate. Probably could've done it in the car but it was just a couple of bolts and less than an hour to pull it, install plate and put it back in. The B&M external balance flexplate is SFI approved and eliminates the need for weights on the convertor! I made sure and marked the convertors relations ship to the cutout so it bolted in perfectly.
Re: My 63 Dodge 330 Project: #428236
12/03/09 12:59 AM
12/03/09 12:59 AM
Anonymous OP
Anonymous OP
Playing around with the mini starter mocking it up on the trans with the bolts to make sure everything is kosher. I hate suprises.
I removed the extra terminals and the whole thing went in smoothly save for a dowel pin on the passenger side of the motor that was too long. Shaved it down and everything went together smoothly!
