Need Gen 1 CTD help #2398572
11/04/17 10:21 PM
11/04/17 10:21 PM
Mid Michigan
Mr. Smurf Offline OP
Mid Michigan
The intake heater grid on my 92 W350 has decided to quit working, the dash light cycles, but nothing happening under the hood.
All the connections are clean & tight, I've no clue where to go next.
Any help is appreciated.
Ed
Re: Need Gen 1 CTD help [Re: Mr. Smurf] #2398594
11/04/17 11:27 PM
11/04/17 11:27 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
First check continuity of the grid...don't know what the resistance should be but open is bad...
have you checked for power to the grid?
Is the Relay clunking(mine always made a pretty loud actuation noise) - if not check for power to the relay. Test for a signal to the switching side of the relay (low amperage side)
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Need Gen 1 CTD help [Re: W.I.N. Racing] #2399169
11/06/17 02:13 AM
11/06/17 02:13 AM
Mid Michigan
Mid Michigan
Haven't had a chance to look at it yet....hopefully tomorrow.
Thanks for the input.
Ed
Re: Need Gen 1 CTD help [Re: Mr. Smurf] #2399425
11/06/17 04:10 PM
11/06/17 04:10 PM
Guitar Jones Online laugh2
Check for codes first before anything. Turn the ignition on, off, on, off, on. Watch the check engine light it will flash 2 digit codes. 55 is the end of the sequence.
11 No Crank Speed sensor signal during cranking
12 Battery connection disturbed within the last 50 starts
15 No signal from VSS (Auto or Cruise Control equipped only)
22 Coolant temp sensor shorted or open (Auto only)
23 Air temp sensor shorted or open
24 TPS shorted or open (Auto only)
33 A/C clutch relay shorted or open
34 Cruise control shorted or open (cruise control equipped only)
41 Generator field not switching properly
42 ASD relay (charging circuit supply) shorted or open, or no ASD voltage at PCM
45 OD solenoid shorted or open (Auto only)
46 Charging system voltage too high
47 Charging system voltage too low
53 Internal PCM failure
62 same
63 same
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Need Gen 1 CTD help [Re: Guitar Jones] #2399993
11/07/17 03:57 PM
11/07/17 03:57 PM
Mid Michigan
Mid Michigan
I did check the grid for continuity, all good there.
Will look at the codes tonight.
Ed
Re: Need Gen 1 CTD help [Re: Mr. Smurf] #2401979
11/11/17 04:24 PM
11/11/17 04:24 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Really check the ground wire at the grid (the one under the bolt). They will go crusty . Otherwise, I'd suspect the solenoids on the left fenderwell.
Re: Need Gen 1 CTD help [Re: superwrench] #2402312
11/12/17 01:18 AM
11/12/17 01:18 AM
Mid Michigan
Mid Michigan
Will do.
Haven't had time to get close to it, had to cobble a denso starter for the tractor tonight.
Ed
