Re: Hellcat fit - hood
[Re: Charger727]
#2400310
11/08/17 02:12 AM
11/08/17 02:12 AM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
We have a 71 Duster equipped with frame connectors and a Dana 60 rear needing an engine, and we are looking at the Hellcat crate motor as a possibility. We aren't afraid to go with an aftermarket front end either, but it has a really nice dual scoop hood all painted in the Twister style - hate to hack that up There was a hellcat superbird at sema and they had to lower the engine so it would fit under the stock hood. https://www.youtube.com/watch?v=5UElCCobzWc
[Re: SRT6776]
#2400369
11/08/17 10:48 AM
11/08/17 10:48 AM
Posts: 2,968 Far Northeast.
mymcodebee
Far Northeast.
We have a 71 Duster equipped with frame connectors and a Dana 60 rear needing an engine, and we are looking at the Hellcat crate motor as a possibility. We aren't afraid to go with an aftermarket front end either, but it has a really nice dual scoop hood all painted in the Twister style - hate to hack that up There was a hellcat superbird at sema and they had to lower the engine so it would fit under the stock hood. https://www.youtube.com/watch?v=5UElCCobzWc They used a modified magnum force front end. I called them to see if they are making them this way or it needs to be totally redesigned. No call back as of yet?
[Re: Bull1tt]
#2401202
11/10/17 12:15 AM
11/10/17 12:15 AM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
The HDK Suspension front end allows a Gen II Hemi under an A-body flat hood with 2x4 carbs. He has done Gen III as well, give Denny a call. I have my 605 Hemi with a big single plane intake and a 1250 Dominator under a shaker hood on my Cuda.....
[Re: Charger727]
#2401387
11/10/17 02:02 PM
11/10/17 02:02 PM
Posts: 1,541 USA
hudsonhornet7x
USA
In order to fit a Hellcat crate motor in a A-body - is a hood cut-out required to allow room for the blower?
That's the way it looks based on the gas monkey dart & roadkill charger I have personal experience in fitting a 68 B body. With the stock K frame, a scoop was needed for sure. I would imagine that an A body would be even worse. Expect to ship the K frame and also allow for the scoop. It is a very tall intake system.
[Re: rck850]
#2401511
11/10/17 06:37 PM
11/10/17 06:37 PM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Man I saw a Gen 3 in an a body on facebook and boy was it tight side to side. Headers must be a nightmare.
[Re: pittsburghracer]
#2401596
11/10/17 09:47 PM
11/10/17 09:47 PM
Triple Threat
Renton Washington
Man I saw a Gen 3 in an a body on facebook and boy was it tight side to side. Headers must be a nightmare. They're tight, but they clear everything. Unlike my Hedman headers and Milodon oil pan on my small block.
[Re: WO23Coronet]
#2401744
11/11/17 02:42 AM
11/11/17 02:42 AM
Posts: 1,385 Ohio
rck850
Ohio
You may be out of luck, have you considered a pro charger? I was really impressed with install they did on one of the show's on Spike TV a few weeks back with the P1SC. I already have an Alterkation front end if that makes a difference. I just don't know if that's the route I want to take.
