Oil Pump Drive Length For Indy Max Pump? #239968
03/01/09 03:39 PM
03/01/09 03:39 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
I need to know which oil pump drive I need for the Indy max pump. Milodon lists three diferent part numbers with a bronze gear. Anybody know which is the correct length?
Thanks Doug
Re: Oil Pump Drive Length For Indy Max Pump? [Re: dvw] #239969
03/01/09 08:35 PM
03/01/09 08:35 PM
Hamiltucky
RBDuster Offline
RBDuster  Offline
Hamiltucky
I am running the stock length with a single line.
Re: Oil Pump Drive Length For Indy Max Pump? [Re: RBDuster] #239970
03/01/09 11:26 PM
03/01/09 11:26 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Thanks, thats what I needed to know.
Doug
Re: Oil Pump Drive Length For Indy Max Pump? [Re: dvw] #239971
03/01/09 11:32 PM
03/01/09 11:32 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
You need to run the proper one that matches your oil pump body. If your running a stock HV oil pump, then a stock length one will work. If you run the milodon pump, they have a longer/wider body you need that drive. In my case with the Indy maxx block, I ran a duel line setup which I used a stock oil pump (HV mellin) with the Indy pump cover, and run the other line from the galley port beside the timing cover. The pump cover doesn't effect the shaft length.
